I've acquired a Cyrus CDTX SE transport....and am aware of the expensive, matching PSX-R PSU.
As well as being highly priced...this PSU is overkill for my purposes, as I intend to supply ONLY the CD transport.
As I understand it (bear with me here!🙂
)....the smart supply communicates with the load (transport) and delivers appropriate power (+/-21V)
Has anyone discovered a way of circumventing the 'smart' bit, so that a simpler (cheaper!) PSU can be used?
Perhaps there's already a product 'out there' that can be tweaked for purpose??
Any ideas please!??
Any ideas please!??
As your only using the cd transport whats wrong with the supply already there ? How do you think an external supply is going to improve the transports performance ?
...EXACTLY.....is this just another example of audiophoolery??
Folks 'out there' are convinced that there's a benefit....or so they say!
Interesting if supposed benefit could be objectively demonstrated.
The PSXR is just a current enhanced set of 317/337 regs, nothing special about it. In the case of a CDP the current enhancement is probably wasted anyway. Just the addition of one more independent regulated PS will have the same effect.
The PSXR isn't just a more powerful supply it intelligently separates more noisier sections of the CD player .
That is an engineering improvement not an "audiophool " one .
I have the XTSE 2 player + PSU .
If it was just about "a bit more power " I would never have bought it.
OK...this where I came in!! 🙂
Can a sufficient supply be made...or tweaked from an existing product?
Or does Cyrus have me by the 'you know whats' in this respect??!
Any decent CDP or even dac would/should have several transformers in order to achieve isolation, only Mission have hypnotised their customers with the tiny cute boxes and the need to add more of those. Pure marketing genius.
There are twin transformers in Cyrus equipment .
Sorry Tonewheelkev I haven't got a circuit diagram but I contacted the factory at the time --NOT the dealer and they advised me .
Now everything goes through a dealer I got my equipment upgraded direct from the factory.
You used to be able to buy second hand power supplies in UK hi-fi magazine advertisements for around £200 its a long while since I checked Cyrus's prices but they used to sell at £500.
Are you sure your CD transport has a socket for the external power supply ? Of the models I looked at to get an idea of what the external power supply is supposed to do there was no socket for one on any of them. Maybe yours is a model I didnt look at .
Hopefully here's a pic:
https://i.imgur.com/Bx5V56y.jpg
Rear RHS---use PSX-R only.
I just walked 5 paces to my unit and it is connected ( you had me doubting for a minute ) .
There is an additional steel plate there so its possible some models don't have this upgrade but it can be done at the factory.
Cyrus CD XTSE2 CD Transport - Preowned - Trade Classifieds - HiFi WigWam
Hi Duncan2...thanks for the inputs....much appreciated!!
Think the link you posted is to an SE2...mine is just an SE...
Not sure what the difference is....but as you can the PSX-R socket is there on the image of my SE that I linked to!
Upgrade-Price-List-consumer-Jan-2019.pdf
As I posted the XTSE has a revised power supply with SEPARATE circuits for the servo motors and low level signals .
-Cyrus CDXTSE2 Plus CD Player | Archive | Cyrus Audio | HiFix
Hope things aren't becoming fraught here!!
The link you posted seems to refer to the SE+ and the SE2....or am I failing to spot the SE?
Or is it the case that the SE the same as the SE+....and the SE2 in this respect??
Here's my SE : https://i.imgur.com/Bx5V56y.jpg
Looks the same as mine except for the plug you have in the power supply socket.
I got the internals updated so on power-up its shows-
XTSE2 on the display what does yours show as that's the proof of MK number ?
Cyrus made many modifications including a SE+, the SE2 was a step above that .
When I finally did get my hands on the unit....my display shows it to be CD XT SE+ ...(the + not being shown on the label at the back!)
Does that imply that at some point, it has undergone an update?
On power up...display shows : Ver4.3 / 2 Nov 2009 / Servo v1.7 / Xt se+
I don't get the power up ver. display but I get the XTSE2, yours is only a slightly older update than mine I upgraded from XTSE+.
Your right yours has been updated its not the standard version .
I cant remember what the changes were but I will try to find paperwork I was sent.
- Power Supplies
- Alternative PSU to ludicrously priced Cyrus PSX-R
