Hey all,
I would really like to have a nice R-2R DAC, but make it myself. Any great kits out there? I can not seem to find any with a reasonable price tag.
Thanks!
Thanks!
Nowadays 'R2R' in relation to DACs has come to mean 'multibit' - if you didn't mean a literal R-2R DAC (with logic chips as switches and ultra-precise resistors) then I have one :
PhiDAC hex kits with pre-built filters
The DAC chips I'm using in this design are true multibit but instead of using resistors, use capacitors. The advantage is that the chip is immune to ageing because it constantly refreshes the charge on its capacitors to maintain accurate binary weighting.
Thanks abraxalito,
I was actually thinking of a literal R-2R resistor based DAC.
I will, however, check your out. Sounds like an interesting design.
You should check out my discrete R-2R modules, if you not already have....
They're not really kits, it's pretty hard to mount the BGA chip and all those SMD resistors by hand....
@SiliconTi, it is not easy to create your own R-2R DAC, you can buy one ready-made, or alternatively look for a chip based which is verified and works well ... often it won't be like a kit, but you buy your own parts, you don't need a lot of them there ... to create your own R-2R from resistors means to get resistors that are accurate enough, and not only that, you also need low resistance switches ... the sound will not be as good as you would achieve with a high quality chip
You can find complete DIY R2R modules, a pair for $115 there:
???响
Not a complete kit, just fully assembled DAC modules with self calibrating CPLD control logic and the I2S or RJ protocol inputs. The rest is on your own to built a DAC.
I wouldn't do that, as on the same website you get complete DAC of very good sound quality for $350.
???响
altough it claims 24-bit, the reality is only about 14-bit?, for a logic reason: the resistors accuracy ... for 10-bit dac the accuracy 0.1% is expected, for 14-bit it is 0.006% ... as it gets deeper, the switches resistance accuracy does matter more 😀 .... for 24-bit R-2R dac the resistance accuracy of resistors and switches should be 0.000006% ... which is possible in chip on some advanced technology, but impossible as a solid state 😀 ...
soekris offers at least sign-magnitude which reduces glitch
They seem to be unavail (sold out):
Soekris DIY Products — Mod House Audio
I do have the dam1921, dam1941 & dam1121 in stock, as do Mod House.
The dam1021 is sold out for now, but I'm planning to make more....
All the finished products are also sold out, waiting for next gen....
Are you saying that DA-8 modules are not sign magnitude? Who told you this? Secondly, do you know how resistors accuracy is resolved in TDA1541/3, TDA1387?altough it claims 24-bit, the reality is only about 14-bit?, for a logic reason: the resistors accuracy ... for 10-bit dac the accuracy 0.1% is expected, for 14-bit it is 0.006% ... as it gets deeper, the switches resistance accuracy does matter more 😀 .... for 24-bit R-2R dac the resistance accuracy of resistors and switches should be 0.000006% ... which is possible in chip on some advanced technology, but impossible as a solid state 😀 ...
Am I saying that? Idk DA-8, I just mentioned that soekris has it, if DA-8 has than good for it.
TDA1541/3 and 1387 are multibit, but are not R2R ... 1541/3 is based on active elements, so the 1387 is continuous calibration ... therefore their operation internally differs from a pure R2R architecture, it uses a mixture of switched current sources for the lower bits and multiemitter transistor current dividers for the upper bits. I said something about difficulties in R2R accuracy of solid states.
I have seen all of those linked to.
seokris, I really like yours, but with the dam1021 sold out, I am not sure of the DIY-ness of the OEM boards. What do they need to be complete?
+1
All the TDA15XX and TDA1387 are current-source based rather than resistor based - one consequence is they have higher output impedances than R2R types being true 'current out' designs. R2R DACs can be designed to be 'current out' the trouble for them is then they have effectively zero output compliance. AD5547 is one such example.
The Modhouse description is a bit vague...I do have the dam1921, dam1941 & dam1121 in stock, as do Mod House.
what's the difference between the DAM 1941 and 1921? What is the Accessory PCB $35 ?
And are these "OEM" products ready to play? Or is an output stage (buffer) needed?
Have you read through the product manuals? It is all in there. A search of this forum can also help.
I have a DAM 1121. You will need +/-5VDC rails. No additional output buffer stage needed. The unmodded SQ of the 1121 is better than the 1021 according to some folks.
Your comment was about required resistor network accuracy and you didn't include a quoting text, but it is placed immediately after my message. Now your explanation makes it clear, but you can't blame the messenger.Am I saying that? Idk DA-8, I just mentioned that soekris has it, if DA-8 has than good for it.
My point was about the fact that calibration reduce requirements for resistor accuracy. It is why it is relevant to your (previously quoted) message. Whether it is a pure R2R (resistor) or I2I network (current source) network, it doesnt matter. my point is still valid, so I don't understand a reason of your arguing that TDAxxx is not R2R architectuire. This is also a ladder architecture and works on the same principle, so calibration makes sense.
Once the above is clear. It is advertised that Audio GD DA-8 modules do self calibrating. I am interested how it could be done.
TDAs discussed are not i2i, but rather binary weighted and it is not the same principle 😀
In DA-8 another technique is used for the correction (based on description), idk details
I did not find any measurements or evidence that it could handle those 24 bits successfully.
- Digital Line Level
- R-2R DAC Kit
