Shanti Dual LPS 5V/3A , 5V/1.5A
Cdsgames, Some new small profile clocks are starting to appear in China, Accusilicon AS318 going for as little as 28 cents each on Tabao. They are same clocks Topping used in their AK4499-based D90 (only they used the version in larger cans). Very good sounding clocks after they warm up for a couple of days. There are also some USB boards starting to appear using the same clocks. IMHO, they clearly sound better than off the shelf NDK SDA. Probably drop right into Allo dacs too. Might want to check them out. http://www.accusilicon.com/docs/AS318BM.pdf
Hmmm I find it harder and harder to distinguished improvements on my regular setup.
Even on the best setup I am wondering if some of the perceived improvements are psychological or real...however
The THD on the clock divider is very closely aligned with theory of euphonics (mostly 2 and 3 harmonic) and a lack of higher harmonics , in a sense closer in FFT (and better) to AKM DAC ICs. Yes it beats even the AKM4499 in FFT (THD but not in N)
The hardware stays same , its just a new firmware. ASR has the firmware that everyone receives .
What's your regular setup, including cables? You ever compare to the sound of really good R-2R dacs? Yes, they have worse looking FFTs but they sound different in some good ways. That something is what we're still missing. One part of it is being able to hear long decaying reverb tails from the room in which music was recorded. Those details are still getting lost, and its not for reasons that show up on FFTs. (of course, one can still hear the strongest reverb sounds, its the subtle stuff that I am talking about...)
Two things that stand out with Accusilicon clocks are full and detailed bass, and wide stereo soundstage. They don't show up on FFTs because they are not due to stationary nonlinear distortion.
My regular setup is a class A amp with focal aria bookshelves . I also test with my own class D instead of class A
My main setup has a pair of Focal electra BE
Hmmm. Probably easier to hear differences with some other gear.
What about cables, they can have audible effects (worth some study: https://www.edn.com/loudspeakers-effects-of-amplifiers-and-cables-part-6/ ).
Also, what about equipment used for checking dacs with headphones? Headphones are what I use for checking some things, and big electrostat speakers for checking other things.
