Which one to keep ? Aleph 4 vs Aleph J
What about DF? It's not just power difficult speakers need...
+1
Max. power is just out thing. Looking at the impedance curve of the B&W 800 shows that you need an amplifier with low output impedance (=high damping factor). Since the impedance dips to 3 Ohm, you'll want high output current.
As I wrote before: crank up the bias current of your Aleph J!
You could also increase the negative feedback to further improve the damping factor.
Or you could just get some better speakers that are more suitable for your amps.
...you need an amplifier with low output impedance (=high damping factor). Since the impedance dips to 3 Ohm, you'll want high output current...
My speakers are a fairly constant 3 Ohms (Apogee Stage) all my Papa amps can drive them to uncomfortable levels.
...As I wrote before: crank up the bias current of your Aleph J!...
That was the idea of planting the seed. I doesn't take a lot of imagination to arrive at a J2 with big boots.
Building blocks:
Cascoded AJ/J2 front end driving a current sourced emitter follower (see ZM's Babelfish ᄅſ for emitter follower).
BAF2015 Schade feedback amplifier, ditch the Shade feedback.
Connect the global feedback.
Give it a name - Leggo.
Job done.
Hmm, I don't get it...
...The Aleph 4 does have more punch when running at full power, and yes occasionally I do run it at 100W...
Take that as the yard stick (or meter rule, whichever you prefer)
100W into 8 ohm is 28.3V rms at 3.53A, 5.77A at 3 ohm.
Supply rails will need to be around +-35V.
35V x 2A bias is 70W per device (upper and lower) at idle, a little too much for a single TO-247.
If you want to crank the bias to 3.5A, that would be 122.5W per device.
Big boots :up: That's probably as far as I'd take it, about a 1/3rd of the rated dissipation.
