Question about replacing the surround foam
12" driver,
that I cant push it down only move it up,
do you suggest to replace it surround foam
The only issue that I not like to do is remove the dome/cap or try to balance it on gluing.
The problem with the cone excursion is understood.
It is more likely to be a rear suspension fault than a front suspension fault.
Inspect the rear suspension. Is the corrugated spider still attached to the voice coil former as shown in the attachment?
