Polar measurements with automatic turntable
Well, I have the,
- slewing ring (lazy susan w/gear)
- pinion gear
- circuit board
on order from Germany.
All I have to do now is settle on a,
- Motor
- Power Supply
- Jack for Power supply
- USB B male cable to a port of some type.
@ Jean Claude
Why not place your order at Mädler in Germany.
@ David
Yes, "Gedotec Drehbeschlag" will work and Pololu with 67 rpm also.
Heinrich
Hello Heinrich,
Can you explain the math here, (cut and paste from another forum)
The phidgets encoder has 360 counts per rotation. In the following the calculation of the parameters:
sprocket = 176
pinion =11
Motor = 139.150696
Decoder = 360
factor = 2226.411
A = 1000
B = 2226411
Hello Heinrich,
sprocket = 176
pinion =11
Motor = 139.150696
Decoder = 360
factor = 2226.411
A = 1000
B = 2226411
Nevermind, I found the info, 🙂
The two scaling factors for the encoder determine the angular position of the turntable. The following information must be known for the calculation:
n = number of teeth of the pinion
N = number of teeth of the slewing ring
U = reduction of the geared motor
I = number of pulses of the encoder per revolution
The factor A is a pure scaling factor and can be freely selected. The calculation of the scaling factor B is as follows:
Scaling Factor B = N / n ∙ U ∙ I / 360 = Impulse / °
Example:
n = 11, N = 176, U = 131.25, I = 16
Scaling Factor B = 176 / 11 ∙ 131.25 ∙ 16/360 = 93.333 p / °
Since both factors can only be integers, A = 1000 should be chosen because of the better resolution (taking into account 3 decimal places).
Scaling factor A = 1 and B = 93 or for better resolution
scaling factor A = 1000 and B = 93333.
I will be doing the final wiring on my Arta turntable tomorrow and giving it a spin, but I could use some help with setting it up.
I am using,
- Hefter 330mm slewing ring
- Mädler 11 tooth gear
As shown in the Arta table documentation, but for a motor I am using the,
- Pololu 150:1 Metal Gearmotor 37Dx73L mm 12V with 64 CPR Encoder.
What parameters will I need to adjust in the following two windows?
- Parameters USB Rotary Table
- USB Rotary Table Parameter Fine Tuning
I expect Scaling Factor A and Scaling Factor B will need to be adjusted?
Any help would be appreciated.
Thank you, David.
Sometime in the 50's my father built an Xmas tree turntable - complete with slip ring commutators and AC sockets on the table. By the time I became conscious of it, its friction drive to the gear motor had worn out and it wouldnt turn anymore.
That's quite a piece of art you have there, David. I bet it still works 50 years from now~
Who knows what USB will be thought of after such passage of time.
I have a motor with 131:1 / 64 CPR, so the scaling factor will be different with your.
I played around a bit with the Acceleration, Decelleration and Speed to get the turntable to behave as it should with the load i put on it.
Here's my config:
[Rotary Table]
RotaryTableType=2
[Application Setup]
AutoSaveSetup=True
[MotorUSBBoard]
P_Factor=90
I_Factor=0
D_Factor=0
MaximumPWMPower=90
MinimumPWMPower=10
AccSpeed=5
Speed=10
DeccSpeed=5
[EncoderUSBBoard]
ScalefactorA=1000
ScalefactorB=93863
UnitPosition=°
[Rotary Table Simulation]
PositioningTimeSec=1
Hi David,
the calculation for the Polulo 150:1 gear motor is as follows:
Scaling Factor B = N/n ∙ U ∙ I/360 = Impulse/°
N = 176
n = 11
U = 150
I = 64
B = 426.666
If A = 1000 --> B = 426000
Heinrich
My ring gear is 178 tooth (both my wife and I counted it 🙂 ) and here is the math I came up with,
N = 178
n = 11
U = 150
I = 64
B = 431.515
If A = 1000 --> B = 431515
Here is the thing, that number does not work!
For some reason, it is off by a factor of four.
Through trial and error, I am using B=107225.
I double checked that I received the motor I ordered, and it is indeed the correct one, as well as all the connections.
Pololu - 150:1 Metal Gearmotor 37Dx73L mm 12V with 64 CPR Encoder (Helical Pinion)
^This one.
Here is a short vid of the table moving from 0º-180º-0º
Arta Turntable 0 to 180 to 0 - YouTube
And some pictures of the motor, connections and software settings.
Any thoughts as to why Scaling Factor B is so wrong?
Thank you,
David.
David,
I have just finished my table using the same Polulu motor as you (Polulu ref 2828 ) and I have the same problem : I have to divide by a factor of 4 to get the correct rotation.
I would really like to understand !
Any idea Heindrich ?
Jean Claude
For sure,
I use 30 x 50 mm aluminum corner with 3 mm thickness. I make my motor support in two parts to allow easy final adjustment and also add adjustable feet at the bottom.
I also place a 40 cm x 40 cm sheet of lead (7 mm thick) below the base plate to incease stability.
Here is the gear in situation
Hi Heinrich,
Thanks for the answer, unfortunately the Phidgets motor is now discontinued !
And you are right, it seems related to the way the interface interpret the CPR
Hopefully, a solution could be found.
In the meantime, when the table rotate let's say from 0° to 180°, it accelerate, then slow down, then accelerate again and so on until it reach it's final position. It can be seen in the you tube link Davefred just posted a few post above:
Hello,
I am starting to use my Arta rotary table and I find it "jitters" excessively when "settling" into each incremental stopping position.
Can a few people share their "Parameters USB Rotary Table USB Power Board Setup" setups?
Thank you,
David.
