350M per mask set? I think this is grossly over inflated.
That's right it's more in the millions range.
Now I understand why AD has made a strategic plan to milk Hi End manufacturers and audio diyers with their 797
George
George
JC, how many of your customers hooked them up themselves or even looked at anything but the front panel? They must have had kittens when they saw all the ugly wires sticking out destroying the aerodynamic beauty.
George,
We can talk about the effect of the milling bit template on cracking, the issue shows up in more than aircraft.
But tempering is more of a material rather than a machining issue.
Thanks Ed.
You touch upon one of the issues. When a part leaves the CNC mill, it looks like having a mirror finish. Not enough for aircraft world. It will go for further surface finish, mechanical or chemical process or both. Then the heat treating. Then the final surface hardening. And all the interim meticulous cleaning steps. And then surface passivation, painting.
But I wrote of lack of crack (and corrosion) propagation control, i.e. past the surface initiation level.
Cal, yw. Up to 20 years ago, US space vehicles aluminum construction still followed the B707 design options (you have to see it to believe it)
George
Markw4 appears to have perceptive ears, unlike most of you out there.
Might be, but I value highly what should go between them.
Like M. Headr**m? The name tells the program!
Like the overloaded resistor: Sorry, could not resist.
I can provide a ballpark as of 2019: one e-beam pattern generator ~20M, one KLA reticle inspection (against the design database) ~30M. A full mask/reticle shop including the clean room, for the 5nm process node, is close to 1B. For the next gen 2021 2nm process node, probably double.
That’s why the industry moved over to the fab model - TSMC, UMC etc. Most companies can’t afford dev and marketing costs plus the capex to maintain a SOTA fab. Better for companies to focus on product design and dev and leave manufacturing to specialists. I think analog is a bit different because of the process specifics so where I worked, that was in-house (RF and power controller IC’s).
Back in 2012/2013 a mobile phone chip mask set cost us $1.5 million per chip on 8”.
Nitpicking and quibbling again, your specialty. Would it be any other reason why the "hi end audio" would complain about the price of the AD797?
Given the fact that you couldn't bring up a cite, your answer is basically "yep, it was attacking a strawman" .... 😉
In this short subtopic exchange, John Curl explicitly stated that he wouldn't choose the AD797 for sonic reasons, further, he argues that -by using the same reasoning when blaming "hi-end-audio" as a rip of - the price target for the IC should be considered as a rip of too.
It is the exact equivalent of high-priced-audio. A few of the members of this group can also sound good.
You should know by now.
As soon as something becomes a 'lifestyle' product it generally is a ripoff in performance:cost ratio. The value judgement is completely different. However the AD797 as an instrumentation amplier is not poor value IF it is the only part that will give the required performance. If newer parts work better then its a case of the price is due to having to hold stock for legacy products. Seems to be apples to eggs comparison going on, which JC loves to do to stir things up a bit.
WBT phono sockets at $50 a pair...How could anyone defend those?
That's what I think it means, but I don't know about other people. JC seems to think it has to have smooth edges? Does this also apply to the audio or just the box?It is the exact equivalent of high-priced-audio. A few of the members of this group can also sound good.
As you've said, it needs more than just comparing material costs to end price if one wants to judge the "fairness" of a price point. I'd assume that John Curl wanted to point to this fact, which seems to be often forgotten when talking about ripoffs in "high-end-audio" .
Regarding the WBTs - if it is the "NeXt-Gen" one could argue that it is a special case of ingenious design work (afaik no other plug-socket combo exists as a match), manufactured in Germany with presumably quite high initial costs, worldwide distribution in quite small quantities.
Good example for the difficulties to judge about price tags; reminds me to the our discussions around the EAR phonopreamplifier in another thread. It seems that most people grossly underestimate the investments and costs (and difficulties) of running a (small) company.
It's kind of oversimplification, but it is easier to judge for big business; if a company is able to generate profits in the range of 20 - 50% from revenue, it is almost certain that ripoff takes place.
WBT claim their nextgen works with any plug. My view on that is that, once you are at hypertac prices (and beyond) for a flawed connector concept then why is the rca turd continuing to be polished. Bung Limos in and just use something better.
Me I'm moving to sub-D connectors for audio 🙂
It surely works with any plug, but the unique impedance feature will be ensured only with an accordingly designed plug; I think currently there is still no other plug of this kind available.
We've talked about the Hypertac and Odu solution earlier (an ODU chinch plug was around 50 DM ~1990 in small quantities) and IIRC the Lemo stuff was quite expensive as well already 35 years ago.
It is a flawed connector concept overall wrt compatibility but a combo from WBT surely isn't flawed (am I missing something any parameters worse?) and one still can't neglect the huge base.
Try to find a sub-D with Odu or Hypertac elements and then lets talk about prices again. 🙂
I don't see a 75Ohm RCA as being something the world needs. BNC already meets that requirement very well and is a better connector to boot.
Installed base is fine, but since the early levinsons only Naim has had the testicles to stick with what they believe is better (and ok keep the user base tied in).
For me if a normal D-sub is good enough for studio work (and good enough for space) then its good enough for me.
Bill,
Can we talk pro? XLR influenced Neutrik NC3...
They also make high quality and interchangable RCA style thingies.
Fair point, but that's mainly another discussion.
When considering the price tag (or it's justification) we can't neglect it.
WBT isn't a device manufacturer, instead they started ~1985 to fix some problems of the flawed connector design; it's a different situation, isn't it?
Sure, different needs.
You learn to love products like Odu/Hypertac if something like testing of equipment is your concern where dozens of plug-in/pull-out cycles per day are needed.
Depends how you view it. For me the solution is a better connector type. Even DIN (bar horrid 2 pin speaker connectors) is superior in almost every way.
From working in space and telco I love high performance connectors. Lousy at soldering the big circular ones though.
- Member Areas
- The Lounge
- The Black Hole......
