1632 is £2.42+tax and are in the phono preamp I have still to complete. But you stick with conventional topologies and I erm...don't 😀
Good enough. 🙂 Not tempted to use sockets for, you-know-what? 😎
No
Maybe because it can deliver 20Vpp at 280 KHz?
Or the 110 MHz GBP,
or the 450 MHz GBP with decompensation capacitor?
or the 10 uV input offset typ.?
Or the -120 dB thd @ 20 KHz?
It must really hurt not to be able to read a data sheet.
But then it may help the business narrative not to understand things.
Now back into the ignore list.
Or the 110 MHz GBP,
Then WHY is the AD797 still so expensive? I would like a real reason.
Because it's likely currently sold (in small quantities) mostly for professional applications, as a price-no-objection part, and both AD and the distributors are capitalistic monsters that don't care about the infinitesimal "high end audio" (whatever that is), or DIY Audio markets.
Otherwise said, "because it can".
John,Then WHY is the AD797 still so expensive? I would like a real reason.
It’s just not as low in costs as some others, but to call it expensive for all what you get seems like an unfair characterisation.
As far as I’m concerned it’s a complete non issue that has everything to do with pure commercial strategies.
Hans
I agree, Hans, it is a marketing decision. It is a popular part and they charge what they know that they can get for it. It is brought up repeatedly, because some here like to 'crow' about how much 'mark-up' there is in some hi end audio products (because they can get it as well) while ignoring that hi mark ups are common in other products too.
@billshurv,
Understood; I just thought, you might have spotted something I wasn't aware of, therefore my question.
@scottjoplin,
from previous discussions about the meaning of terms, I concluded that the underlying communication problems made it a waste of time and so I'd better refrain from such.
Despite the previous explanation in my post, it seems that you still haven't got why John Curl brought it up.
I hope reading his last post:
The Black Hole......
helps a bit in this regard.
As a "strawman" is based on intention but not on stubborn misunderstanding, I'll retract it..... 🙂
@scottjoplin,
Parroting the strawman word doesn't make anywhere accurate. Have fun, though.
So, the intent was to take revenge, that is it turned personal.It is brought up repeatedly, because some here like to
Do you speak also on behalf of anyone else on this? (you weren’t the one who did the first shot)
George
Or the 110 MHz GBP,
Not bad for a 36V 600MHz ft (ancient) process. 😉
Please stop asking me, I'm retired and have only a few friends left at ADI. I could say I'm a free man, ironically I was called for the first time in my life as a juror and when I showed up they gave me a number, "You are number 6". Perfect.
- Member Areas
- The Lounge
- The Black Hole......
