I like John Atkinson's parting words: "... its distortion signature will have no effect on the amplifier's sonic character."
Right on PMA! I saw that too, and I reported it to Parasound, weeks ago. Upset somebody over in Asia I believe. I hope to look into it with a hum pickup (sniffer probe) myself when I get the chance. It is embarrassing. I never checked the distortion, etc without my 400 Hz filter in place so I overlooked it, until I saw what JA measured in the review. Next time I will be more careful.
So, after have been flinging poo L & R here, the embarrassment is understandable. Maybe an excuse to everyone you have dissed would be in place?
You, the Almighty?
You, the Almighty?
Plenty of people have dissed John too. Maybe apologies all around are due?
You, the Almighty?
Please be fair John has little or no control over what actually ships as that product. It's just business at some point.
I have some say in the product, and I can be sometimes annoying to the people responsible who put it together. My very BEST products have been built by my personal team and me, like the Vendetta Research Phono and the CTC Blowtorch. I rarely build my own power amps any more, just not enough space. BUT I do the audio circuit design part still, and I do have finished samples sent to me for final approval. I have a JC-1+ on my test bench in the other room, for example, and I measured it months ago, before a similar unit went for review. It measures OK, for a medium feedback amp, optimized for under 25W operation, but not clipping till at least 450W into 8 ohm, or much more into lower Z loads.
John,
Just a question, no hidden agenda:
Why so much available power, who needs a potential of 1KWatt + when the objective is to get a system that’s optimized system for under 25 Watt.
It is probably no coincidence that up to 25 Watt the Amp works in class A.
Is it just a commercial issue, big is beautiful, to justify the price that wouldn’t be possible with less power or do you realy see auditory benefits.
But when more available power would mean better sound, what would be the next step, 5kW, 10kW ?
Hans
Specific figures in the power of the amplifier are associated with the sound pressure that acoustic systems create. The calculation also has a conception of the sensitivity of these speakers. There are such formulas. They show that in order to create a sound pressure that reproduces the piano at its peak, it is about 110dB, for conventional speakers with a sensitivity of 96dB / W / 1m, an amplifier power of 25W is sufficient. However, for speakers with a sensitivity of 86 dB / W / 1m, 300W is required from the amplifier.
For speakers with a sensitivity of 90 dB / W / 1 m, 1000 W of amplifier is required to create a sound pressure at a peak of 120 dB. This is a level of studio quality.
I repeat that all these three calculations are for a small room with an area of 20m2 and a ceiling height of 3m. Or at a distance of 1 m from the speakers, if they are in an open space.
And these powers are musical peaks, and not constant, like for example the noise of a take-off airplane, etc.
High-End Gold Note - калькулятор звукового давления в комнате, усилите
No, its a requirement as studios are working with the uncompressed raw feed and need the headroom. The end product doesn't as there is compression/gain riding in place.
Thanks George !
Lots more to read !
Dennis, you are welcome.
Bell System Technical Journal past issues used to be hosted at Alcatel Lucent site.
Now, under Nokia, they are found here:
Issues 1922-1983:
https://ieeexplore.ieee.org/xpl/issues?punumber=6731005&isnumber=6772315
issues 1996-present:
https://ieeexplore.ieee.org/xpl/issues?punumber=6731002&isnumber=8760494
Seminal papers here: Bell Labs Technical Journal - Bell Labs
George
You can also get studio recordings with a high peak factor.No, its a requirement as studios are working with the uncompressed raw feed and need the headroom. The end product doesn't as there is compression/gain riding in place.
- Member Areas
- The Lounge
- The Black Hole......
