Bryston 4B SST clone
I could get you this one with gold top, 3.5kw dual 42 volt weight around 30 kilos🙂
Bryston input
Hi Friends, I purchase this pcb's for made clone Bryston B28 SSt2 and supplier send me schematic, only arrived pcb filter, but in pcb input I don't understand why it doesn't carry potentiometer, how do you turn the volume up and down?you need another pcb? a friend told me that I could adapt a 1ooK alps potentiometer, could you adapt that potentiometer? and where to coect it correctly, my design is with 2 pcb's stereo, powered by two toroid transformers of 1000VA each 80-0-80V, I bought 12 capacitors of 10,000 Uf 125V, is there any improvement in the components? still because of the pandemic I have not received several components, only the filter pcb that I have already placed zener, relay, resistors, and regulators 7812 and 7805 I attached photos, if someone has assembled it and changed components to better I would appreciate the help, since the documents that the Chinese has sent are not very good and create me doubts, is a great project for me, thank you all, greetings
  • BRYSTON-28B-SST2_Rev:2.0.pdf
  • BRYSTON-4B-SST_INPUT_Rev:3..pdf
Lowering the toroid voltage is not easy, it would require you removing some secondary windings, not an easy job, the input board is fed together with the output board and dosent need separate psu.
If the toroid is new and unused, can't you return it ? , I wouldn't even try using it.
