Tips and advice on improving my first build
Disabled Account
Joined 2020
Hi all,
First time posting in this forum , I could do with some advice on how to improve my speaker build both aesthetically and with sound quality, if possible.
I built my speaker enclosure based on this design YouTube
I'm currently using a Raspberry Pi4 , a Hifiberry Amp2, a peerless PLS-65F25AL01-04 full range speaker driver and 3 Gpio buttons.
I am using Moode audio for the software side of things which runs flawlessly , I did have a few hardware issues with the Gpio buttons having false triggers , which I resolved by soldering on a low pass filter modification to the Gpio header of the Amp2, details can be found here on the Moode forum Small Speaker project, Gpio problems and how I solved them
I built the enclosure a shade under the size required for the speaker driver , based on an online calculator, however the port is the recommended size. I don't think this impacts the sound quality to much as to be honest the speaker sound great.
Ok to the matter in hand , I could do with some advice on how to improve my build ! , my wife would prefer the enclosure to be smaller if possible so any advice on how to improve the enclosure aesthetically, how to make it smaller if possible , how to tidy up the low pass filter modification, a possible alternative speaker driver to aid making the enclosure smaller or any advice in general would be very much appreciated
thanks in advance .
hi ,
thanks!!! I really appreciate the compliment , yeah I probably should of said that I'm building a few of these speaker for other rooms so the improvement will be for the next speaker's benefit this one is staying as is .
I always think that any project has room for improvement and so it would be great to show iterations of how I learned some thing new throughout the entire project and developed a final superior product .
Yeah I did have a thought about padding material but I worried it would reduce the internal size further ( for this speaker driver ) resulting in poorer sound quality .
Chamfered edges might provide an aesthetic improvement , I might consider that for the next iteration.
Rounded or chamfered edges also can improve the acoustics by reducing diffraction effects.
Its also generally agreed a cube isn't a good choice due to resonant modes all being the same, and its common to see all three dimensions different with drivers not mounted symmetrically too - the idea being to create lots of modes all overlapping to reduce any prominent peaks.
Wow thanks for the reply I will definitely consider rounded or chamfered corners on my next build .
Is there a shape that is more ideal ?
Generally spoken, to make an object appear smaller (or even to make it disappear), it is recommended to give it a dark or black surface. The blacker, the smaller...
This may not apply in a white environment, though. (think "2001 a space odissey")
If you try it, make sure that the color you choose harmonizes with your interior (a blueish black is awful in a wooden interior)
