Nirvana has only one output and 2 way of connecting to it...USB type A or included cable
Size of box is 125mm / 60mm/ 37mm height
Regarding SQ change... subjective camp is very clear that a better PSU means a better SQ. In the objective camps (THD data) I can see a small reduction of harmonic. Personally I hear a difference no matter where I used it (RPI for example vs stock PSU)...except when I do it vs a Shanti (I slightly prefer Shanti but not by very much)
I am working on the page and will publish it in a 4-5 days. I hope to ship ( from India) before end of the month (EU a few days after)
Not the best pics...but I think you will get the feel. Its quite nice in my opinion (look and feel)
We measured around 39C at max load on casing (with 21C ambient)
It looks good, very neat and compact. Custom mains leads for each region or multihead interchangeable plugs?
For those of you that understand... IMD at -110.5 at full signal !
Which IMD test frequencies do you use?
Also, great to hear about your exceptionally good results with ES9038Q2M, and with your other projects too
Of course, some of us still feel that the ESS dac modulator design sounds better with DSD than with PCM (particularly with DSD256 or DSD512). Is there going to be a Windows ASIO driver for Rev?
At last they did test with dual LPS (as we asked since day one) and ok it seems it sounded good...
So frankly I was not that happy.
Yes, there has been a lot of issues around the use of different PSUs and how that effects the sound preferences. Still, the Katana has winning a lot of the comparisons.
For what it is worth, the next sound check seems to be have settled on using a pair of these to drive the boards:
ULPS1225A Dual Ultra Low Noise Linear Power Supply - OSA Electronics
Included
Windows driver included up to 512 DSD. I will check the exact frequency but its the standard ones
I am yet to see any readings on noise on the OSA linear PSU.. until then I would recommend Shanti LPS
Will USBridge Signature output multichannel audio via USB?
Hi folks,
I am looking into upgrading my current setup as follows:
NAS running Roon Core (w/ convolution incl. active XO) - Network streamer (as Roon endpoint) - multichannel DAC w/ pre amp and volume control - power amps - activated speakers
For the Roon endpoint I am considering the USBridge Signature running Ropieee or similar as transport into the multichannel DAC.
Can you confirm that the USBridge will be able to output multi channel audio (upsampled to DSD 256/512) via USB?
Markus
Hi folks,
Markus
We used 60Hz and 7 Khz tones and we have done it also with 917hz and 5.5Khz
Hi Markus
Your DAC has a USB2 input with 300Mbs max (but usually less ) input . DSD needs about 75 Mmb per channel at 512. Frankly I know that RPIs are capable of mutichannel (and so is USbridge) but at 512 you are way too close to pipe size.
We never tested so I cannot say.
Thank you
Also please excuse me if I did't understand, but did you say your Windows driver for Rev will support ASIO (it has always been required for Native DSD in Windows, at least so far...).
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
