100W Ultimate Fidelity Amplifier
AX14
Layout..
My ax14
After many years, my ax14 alive. Sound very good. Deep bass and clear at high.. Picture just for testing only. Will build new board.
C1 10uf
C2 100pf
C7 33pf
C13 dont have if C3 1.5nf
I dont know the exact good value for this all capacitor. Hope somebody can give advice.
thank you mine is same too but bass is not good enough and if i dont connect volume pot 5k or 10k there is too much noise coming to output.
maybe i need check prassi sch with apex sch so i can see the what is different.
thank you again for answer..
I finally started my build. Initially wanted to build the FH9, but then changed to the NX14. Started populating it last night. Then found out I ran out of 220r 1/4 watt resistors. Got some at work today and going to finish it off now. When this build is done Im going to start the FH9, and then the much praised A40.
My AX14 so far
Anybody care to share the last working pcb layout of the P30 preamp?
Cheers
