PCM63P decoupling capacitors
Joined 2015
Hi all,
I am "refreshing" an ADCOM GDA-600 which uses dual PCM63P DAC chips, and seeking advice regarding the decoupling capacitors.
I am familiar with the various mod threads out there. Part of this project is learning about DAC construction so I'd rather not follow those blindly.
I've read the PCM63 datasheet and have the schematic (relevant parts attached).
On the GDA-600, 10uF caps are used on pins 2,11,13,28 (analog and digital power supplies) and pin 4 (offset decoupling capacitor).
A few questions:
1) In the attached snippet, it is mentioned that "larger values (up to 100uF) give slightly better SNR". It wasn't clear to me if they are referring only to pins 1,3,4, or also to the power supplies decoupling caps.
2) Is there value in increasing the capacitance for the PS decoupling caps?
3) What are good types of capacitors for this application? Is this case a good candidate for "audio" capacitors such as ELNA Silmic II, Nichicon UES or UKZ, or rather low ESR caps such as Panasonic FC, etc?
Thanks!
I would avoid the low esr types on the analog side, the digital side may well benefit from lower esr parts, as long as they aren’t on the same power rail.
You may get better bass response using the larger value caps, or it may not make much difference in that particular circuit.
In this case they share the same supply...
From one russian site...
Thanks! if I'm not mistaken it looks like they used 100uF, which is inline with the datasheet.
I think I'll increase the value up to that, as long as the new cap physically fits in the old position.
The DAC currently has general purpose Nichicon VX caps in those positions, not sure which to go with for replacement.
Hello,
Rubycon PMLCAP and KEMET KO-CAP(Polymer tantalium) are supreme for DAC reference capacitor.
But PMLCAP is very expencive outside Japan.
If you intrested PMLCAP, I recommend capacitor kit of PMLCAP.
1189-4323-KIT Rubycon | Kits | DigiKey
Panasonic ECHU is similar to PMLCAP (very thin layered film capacitor), but smaller capacity only.
I recommend KO-CAP plus paralleled with PMLCAP (or ECHU) 0.1uF.
I tested this combination for PCM1792, I got better sound quality.
But I think, can be used bipolar cap for decoupling otherwise Pin 23, 24.
Pin 23 and 24 is used for upper 2bit adjustment, then this section is suitable for nonpolar cap.
Pins 23,24 (C521, C522) in the schematic are 0.1uF.
They seem to be MLCC, or other ceramic type?
Are you referring to Pin 3, "Reference Decoupling Capacitor?
I am assuming this advice does not apply for the PS decoupling caps, on P11, P13, P28 and P2
I seem that cap is MLCC.
I think, ECHU would be better than MLCC.
Page 3 of PCM63P datasheet:
Pin1: Servo amp Decoupling Capacitor
Pin3: Reference Decoupling Capacitor
Pin4: Offset Decoupling Capacitor
These capacitors are would be susceptible to sound quality of capacitor.
They are all critical with PCM63.
I totally agree WRT replacing MLCC caps on any non-digital DAC pins.
As I have stated elsewhere, you can disconnect the BPO track from DAC OP and use a (from memory) 2mA CCS for sound improvement.
TCD
🙂... and play also with the voltage rate of the caps. Anyway, choice is limited by the print board... no smd caps on the picture. Avoid polymer cap in the analog side... (though rules may be broke) . Silmic II are far than neutral and imho will be to mellow with the PCM63 but all is about the I/V and buff as well. I like the choice of the picture that looks like Black Gate for the lytics. Try rubycon pps classic radiall size case too on the digital side. After you have to tune according the rest of the system to go further, low leaking caps here and there and think also to the power regs rails. It's the whole... step by step... try soe UCC polymer caps for the digital side too of the power rails... not too much low esr sometimes but you ears will guide you...if less than 6.5V, some 560 uF have very low esr and nice result but guess : all brand will give you a different result. For instance don't go SEPC caps that low esr often arms but more with the SEP caps serie and so on : you have to balance and it's a long try and error. Specs on the datasheet is a first step to reduce the choice then comes the setuping... at least it's how I proceed, YMMV.
Agreed,
Have my receips as well, made better than E super caps with two Black Gate N... though often the BG can help...
However, this is an equilibrium with the circuity and the rest from my experience... I don't like silmic Ii for instance for decoupling, but it can be needed sometimes, though like them as coupling cap sometimes, and so on....all is about the tipology and the over hifi devices around...now people eq though so caps game is disseapering.
Hi, I know it is an old dac chip, but could you elaborate a bit more for the less expert (like myself :wave:)?
As @Terry has suggested its a good idea to study the datasheets. If you compare for example PCM63 with PCM1702 (its immediate successor) you'll notice on the diagram on the first page that there are three logical blocks contributing to the output current. Only on the PCM63 is the lowest of the three blocks able to be disconnected (pin5). That's a considerable advantage in flexibility for the PCM63 as against its successors (PCM170X).
