Problems with amps having driver board as in picture
Hi
Recently I got few complaints about the amps that uses these driver boards as shown in the attachment. The amp trips when they drive 1ohm into it. Other wise with 2ohms or 4ohms they will play good. But when they get some heavy load they will trip. I want to know where to investigate the problem. Thank you.
Does the amp latch into protection and requires that you power-cycle it to make it turn on again or does it simply shut down and come back on without doing anything except waiting a few seconds?
I removed the driver board to check for cold joints. And checked few polymer box capacitors. Everything looking good. I putback driver board and powered the amp the amp came on and relay clicks but no oscillations at all. Amp only pulls 1 5amp.
There have been instances where the SD terminal was leaking and the internal CCS couldn't pull it up when the muting/SD drive was released.
If this shows up in the other amps, the ICs may be from a defective or counterfeit batch.
As an outside possibility, there could be something with the drive circuit that's damaging the IC.
