Current Dumping revisited
Initial tests. Voltages and currents according to the simulation.
Still without the dumpers. Just testing the class A stage.
Very nice sound! I'm surprised!
RMAA measurements
Did some measurements using RMAA and the internal soundcard of my Intel DH77 motherboard.
Power output was set to 1W due to not using an attenuator at the soundcard input.
What jumps out to me in the measurements is that the noise level is rather high, often much higher than any distortion.
Why would that be? The data in post # 112 was better.
Jan
I have found the noise source is the soundcard output, about 20mVpp. The output level was adjusted via Windows volume control.
I'll have to insert an attenuator between the soundcard and the amplifier, to keep the soundcard output level always at max.
