Replacement without Ferrofluid for SEAS "K 19 F"/H225 (H 225, H0225)/Vifa D19TD
There are a lot of replacements for this tweeters. But I want a version without ferrofluid and with exact the same material for diaphragm (maybe "Supronyl" ??), which provides a very special sound character. Thanks for advices.
This high frequency driver was often used in Mission loudspeakers, e. g. Mission 70, 737 etc. - go to
Mission 70 - Manual - Two Way Loudspeaker System - HiFi Engine
This mentions supronyl.
Monacor DT 19 SU Supronyl buy at hifisound.de
Its a possibility.
Whoops, No its not ferrofluid mentioned at the bottom of the spec sheet.
Its a possibility.
unterI believe seas actually made a version of the H225 without FF (called the H202), but of course it hasn't been made for around 30 years so the odds of being able to find it are probably slim
Seas Tweeter H202
is to find a data sheet but not there:
PRESTIGE TWEETERS
If there is the necessarily of adjust the voice coil, i. e. without automatic centering while screwing (in German language we call this "Zwangszentrierung" - maybe "constraint centering" in English ?, this is too difficult for me.If you find a pair with the correct dome material (Monacor?), you can just remove the FF yourself? I think I might have a pair of those tweeters from a pair of Mission 737R.
BTW - I don't need this tweeter for a one-time replacement. I need the replacement type as basic information, because I have many friends who have speakers with this tweeter in a not working condition.
The D2008 from scan speak resp. Hiquphon's OW-1 is a very good replacement, but the sound character isn't the same, therefore the question in post #1. Nevertheless many thanks for all information so far.
Just replace the SEAS H225 with the modern H0737-08 19TFF 1.
If ferrofluid is removed from 19TFF-1, then they will become absolutely identical, but this is superfluous.
The voice coil will center itself just fine. The magnet is held to the front plate by three plastic tabs. Carefully pry them loose with e.g. a small flat screwdriver. It doesn't take much force, and you'll hear a small "click" as each tab goes over the notch. When all three are loose, lift the front plate with dome assembly off.
Once the tweeter is separated, use a cotton swab (e.g. Q-tip) to very gently clean off ferrofluid from the inside and outside of the voice coil. When that is done, the magnet gap has to be cleaned. Poking a strip of paper into the gap will absorb some of the oil. Repeat with fresh strips until no more oil comes out with the paper.
If the ferrofluid has dried out or become "sticky", you may have to add some kind of solvent to get it out. A few drops of regular white spirit should do the trick, but don't soak the entire magnet.
- H -
- Replacement without Ferrofluid for SEAS "K 19 F"/H225 (H 225, H0225)/Vifa D19TD
