Discussion on what materials to build speakers out of
Solid stone looks fantastic, but the difficulty of using it makes it impractical for most of us.
The stone veneer I'm thinking of using is this stuff: Natural Stone Veneer
Its a thin layer 1 or 2 mm (1mm = a 25th of an inch) resin bonded to a glass fibre backing. I'm thinking of using it instead of a traditional wood veneer, in the hope of producing something that looks like a slate enclosure, suppresses resonance perhaps better than a timber veneer, and will be less susceptible to movement due to changes in humidity etc., with the effect that can have on bending the panels or splitting the veneer.
I've just had a couple of samples delivered and it looks very promising, but i wondered if it had crossed anyone else's radar yet?
Just to add a little, the stiffness is less than the substrate (hardwood ply), and it will be attached with a PVA or similar glue. I don't anticipate any attachment / detachment problems. The idea is that two materials with differing characteristics will inhibit either from freely resonating in the way it would if left on its own. But I accept the idea may be wrong. Tell me if you think it might be.
I guess somewhere there's a billiards/pool/snooker table with some big cutouts! 🙂
I asked the local stone worker for a quote, was > 1000 euros.
Then I just bought a cheap angle grinder with diamond blade (<100 euro), and a few huge slate floor tiles (around 60 euros) and cut it myself 🙂
Actually really easy to do, diamond blade goes through slate like it's butter.
Small ones used 100x50x1.5cm tiles, large ones I only remember the thickness which was 28mm.
All in all took me *way* less time than the normal sanding/painting routine with MDF!
Great idea, never even considered using floor tile for cabinet finishing.
4 year late response!
Tried the thin stone veneer route as described a few posts back above, not sure about the accoustic benefit as I didn't play them without before applying the veneer, and anyway each MA A12pw would have needed running in first. I'm not that patient once started on a job.
I can say it is a good decorartive finish, they were a bit of an experiment, they have virtues, brilliant fast and articulate bass, but top end defenitely lacking something. That's not the cabinet but is almost certainly the A12pws, which are mid bass. Will be trying them active with a pair of MA7p and a pllxo soon.
Moving on, I'd completely endorse Pigmy's view, working stone tiles is easier than I thought til I tried, inspired by his posts here. I've built a pair of small Woden Bulldogs for the MA A5.3, in 12mm MDF first as a frame really, then covered with 12mm travertine (limestone) floor/wall tiles. Needed a special wet saw to cut them to size, but the result is v nice and I can detect no resonances whatsoever. They're in daily use, favourite small speakers so far. I'd recommend using stone tiles, they are a consistant thickness, readily available in UK up to 900mm, (mine came off Facebook Marketplace as left overs from someone's new bathroom), can be cut with the right equipement (my wet saw was only a cheap one for £50, a better one would make the job even easier and can be hired from most tool hire shops), and the cabinets are totally solid. Just don't drop one on your foot.
Floorstanding the weight might start to become prohibitive, though having seen the results I'm still tempted to give it a go.
pics to follow, though they're none of them as nice as the big slate and leather jobs.
Reactions: androxylo
Pictures as requested. Constructive criticism welcome. The ideas are often better (!! or possibly not) than execution. I've included the ugly back to one to show the random exterior anti resonance bracing.
The travertine tiles used on the MA 5.3 have the holes filled on one side, that's the side usually exposed in bathrooms etc., but I preferred the holey side. The felt circle was an anti diffraction something I'd read, whether it makes any difference is doubtful.
Driven at the moment by a Temple Audio Bantam Gold, lovely little class D made in Manchester.
The MA 12pw's were even more of an experiment. The box itself is far from ideal but it did demonstrate just how good a driver the A12pw is. I've some more to build boxes for next year.
Again the finishing could have been better, looking at them again to photograph drives this home. The slate veneer has a nice uneven surface. It can be a b****r to cut cleanly, but a sander takes off surplus fairly easily. Finish with a stone sealant, though a water based acrylic varnish would likely work as well. There are a number of different stone finishes available, red sandstone is tempting.
The baffle covering was another experiment. It is injet canvas printed with a snakeskin pattern and given multiple (5 or 6) coats of water based acrylic varnish, ends up a little like thinner vynyl flooring. Makes the eyes go funny in some shots, but paint can be boring after a while and the colour matched the cones, imo at least.
These had a surprising WAF, having got them down to take pictures they were described as "retro" and "quite nice", and are preferred to the FH-XL s in the background (I suspect because they're smaller though).
