Hi, i have on JL 300/2 4x irf540 and 4x unknow mosfet, somepeople know this mosfet? I don't found info about this device...
To upload photos click the following:
Go Advanced
Manage Attachments
Browse
Upload
Repeat as necessary
Preview post to see how the post will look.
Click Submit Reply to send it to the forum.
Go Advanced
Manage Attachments
Browse
Upload
Repeat as necessary
All of the outputs in the 300/2 are the IRF540.
Ah ok, thanks, but don't is strange? This ampli have 4x IRF540 and 4x this unknow mos..
I did this work for more than 30 years. Nothing really surprises me anymore. They could have been installed by anyone. The solder doesn't look like flow soldering.
Ok, maybe, i don't know..
Maybe you know voltage bias adjust on ceramic resistor for this amplifier?
I don't know what the factory recommends. I've found a lot at 4mv which I believe is excessive. I prefer setting them as in the demo below:
http://www.bcae1.com/temp/ausettingbias.swf
I could not find that part number but it could be a fast schottky rectifier similar to this. https://static6.arrow.com/aropdfcon...21ff47d54a448a832ed42182/sdp20s30_rev.1.4.pdf
It might be sitting near / connected to the coil. Do you have a schematic?
I have changed all r-channel mosfet, but i have this situation on power supply mosfet, drain pin (see picture).
The amplifier work normally, but after 5 min. The square wave is unstable and i hear the strange sound from power supply ( i think from toroid)
What are you powering the amp with?
How high is the DC voltage feeding the amp after 5 minutes?
If you lower the 12v power supply voltage, that waveform will probably look more like you're expecting.
I powering with 40A switching power supply, 12.6V.
What is "dc voltage feeding the amp"? You mean rail voltage?
is the voltage steady at 12.6v?
Is it adjustable?
Yes, i have tryed also with 14.0V, but is the same. I have this square wave unstable also on sg3525 output..
If you play music at a fairly high level, does the amp do this?
Does it produce music normally when the instability starts?
Is it adjustable?
i have played low volume music, i must try with high volume.If you play music at a fairly high level, does the amp do this?
i don't know, let you know.
i have misured also square wave on SG3525 output, is clean, but when instability start (change frequency), also this square wave is unstable. can be sg3525 broken?
I doubt that the is a defective 3525.
We need to check quite a few more things. For now, test at high power.
- General Interest
- Car Audio
- Unknow mosfet
