Thanks Nelson, I can't wait! You can't have too many excellent crossovers after all...
The funny thing is last week when I ordered a Mean Well 24V power supply from Mouser for my H2, I thought to myself, "I should probably order a couple more of these."
I should've listened to myself. 😀
Is that +24V unregulated? A pity there is not a symmetric power supply (+/-) so that we could get rid of the coupling capactiors.
that's bloody optimistic, counting on fact how many series connected capacitors one need to have in active xover stages
I mean the interstage coupling capacitors that are electrolytic. These cannot easily be replaced by film caps. The capcitors setting the slope/frequency of the crossovers must be film caps anyway.
wait for Pa's schematic , then introduce bipolar supply, taking all Vref points to GND
remove interstage coupling caps
easypeasy
easypeasy
easypeasy🙂
There are only input and output coupling caps, no "interstage"
And how's about B5?
Isn’t that essentially what we already have in the diyAudio Store.
Analog Crossover Network – diyAudio Store
Aimed at the LX-mini but very versatile.
dave
me dunno
that's what Son of Gustav presumed ....
ZM Knows Station
Doesn't look as versatile to play with various drivers as the B5 would be. I could be wrong but it looks like component values need to be changed to alter the crossover. With the the B5 you flick switches.
I'd be keen to see a DIY B5.
I believe that this simplification is also in the one we are talking about here as well. If you want to flic switches i think you will need to get a real Firstwatt one.
dave
dave
I tried to reverse engineer the B4. My guess is attached. The Rs have values ", 2R, 4R, 8R, ...
For the LP part of the B4 crossover, opening all DIP-switches will open R9 - R12 (see attachment). This means no signal will reach the inputs of U5 and U6. (Likewise, opening R1 - R4 will the audio straight to the positive inputs of U1 and U2. I guess maybe the gates are grounded via 1Meg?)
/RK
/RK
The Gates are provided with 2 Meg to ground to insure that there is no
excitement when switching or if the resistors are left open.
- Pass Labs B4 crossover questions
