2sk413 2sj118 I'm looking for an amp scheme
Hello friends There are 2 pairs of 2sk413 and 2sj118. I'm looking for a scheme that I can use them. Is there a circuit diagram you can recommend
Talking of the classic Hitachi circuit are there some modern equivalents to
2SA872A/2SB716/2SD756 recommended? They are getting rare, and high in
everything useful (gain, bandwidth, voltage, power).
Of course there are better circuits, but its an 80's classic... (actually a bit more 1980 I think)
I did my own modern copy of the circuit.
For the front end I used MPSA42's and MPSA92's
I wouldnt use the 30pf caps though they need to be be at least 47pf or even 100pf. I also decoupled the front end for better noise performance.
Nothing wrong with using 2n5401 for the IPS, KSC3503 in the VAS
Need a way to control your OPS bias current, put a low ohm pot in series with the diodes
Add some Emitter degeneration resistors on the IPS
Zener clamps for the gate drives
and list goes on.
no.
those mosfets are not lateral mosfets; the zero tempco point of the 2sk413/2sj118 series is VERY different from the one for the lateral mosfets in the 2sk1058/2sj162 series!
see data sheet excepts below.
the simple bias network will not work properly with non-lateral devices!
mlloyd1
Is the attached scheme suitable?
