TSE II - problem with heater regulator
Dear friends,
Please help me to find the problem on my TSE II board (300B tubes)
- T1-GRN1 - T1-GRN2 - measuring 6,3VAC - OK
- jumper from 3-4 - OK
- R2=300R - OK
- R1=100R - OK
- IC3 orientation/soldered - OK
- D1 orientation/soldered - OK
- D5/D4 orientation/soldered - OK
- heater voltage on both 5842 sockets = 7,6VDC - OK
- heater voltage on 300B = 0 ( zerro) !!!
- MIC29502WT - input voltage on PIN2 = 7,6VDC - OK
- MIC29502WT - output voltage on PIN4 = 0 (zerro)
- changing MIC2902WT - still same problem !
- no smoke or anything suspicius, regulator temperature moderate
- HV = OK
I'm really lost here....
BR,
Goran
still nothing...I have resolder all points around regulator and still no voltage on output pin.....on input pin is 7,6vdc...😕
br,
Goran
You should post the schematic here.
Schematic is in post #1 here:
After a 14 year run, the TSE must DIE!
I don't see any obvious build errors.
The first thing I would do is to measure the resistance across the filament pins with no tubes installed. I get 400 ohms on my board in either direction after the readings settle. The pins are rather close to each other and it would be easy to create a short.
Hello Friends,
Look this nice solder bridge bettwen pins...😕😡
It made me almost nuts:bigeyes:
Now is all ok ...5v on 300b heaters...
Huhhh...I will post finished amp on gallery soon...
Thank you all...
Goran
Dear Frinds,
After few weeks of listening the TSEII I have still some problems.
I always had some felling that left channel is slightly louder than the
right channel....
Yesterday I have checked with fingers left channel 300B and to my surprise It was just slightly warm...no problem to hold fingers on it...
Right channel tube was very hot and you can burn your fingers easily...
I have immediately check the bias and It all looks ok... 80mA on both 300B and 174V on driver tubes... Then I swap the tubes from left to right and problem is still there on right channel. I have also measured V-out from amplifier with sinwave and I get 13,1VAC on left and 12,75VAC on right channel.
Do you have any idea what is wrong. Maybe bad mosfet ?
BR,
Goran
If the tubes are both set at 80 mA, and they are fed by the same power supply, then they must be dissipating the same amount of power, and therefore shedding the same amount of heat. Recheck the 80 mA now that the amp has run for a few weeks, since new tubes can drift around for a while. If they are the same, then there is probably some difference in the air flow or reflectivity in the area surrounding the tubes that explains the difference in glass temperature. The temperature on the glass can vary a LOT depending on where you touch it, be careful.
This is a channel imbalance of less than 3%, or 0.24 dB which isn't bad. The usual reasons for channel imbalance are component variations, usually the driver tubes or the volume pot (often rated at 10% or worse).
The 300B's contribute only a little of the total amplifier's voltage gain. The most gain comes from the 5842's, so this is where the imbalance lies.
Try swapping the 5842's to see if anything changes. A slight change in the plate voltage adjustment can affect the gain, so a few volts either way can improve the channel balance.
Thank you George for datiled answer! With changing plate voltage on drivers I prfectly set the voltage on output and now is all ok...much more balanced sound... still one 300b much more hot...but don’t care any more...its sounds perfect now...
BR
Goran
