JFET matching Jig
2Oz copper & dedicated jumper
  • 2oZ copper
    Votes: 15 100.0%
  • Dedicated jumper clip in kit
    Votes: 9 60.0%
  • Total voters
    15
  • Poll closed .
Hi All
i have not heard from anyone not receiving it ( among the last US distribution list). I am planning to contact only US based wait list today and send out request for payment. I will wait one more day if any one in the shipped list have not received to respond - final call. I have checked the tracking and it shows it was delivered.
thanks
kannan
Sent you a PM - please check and reply
kannan
Kannan_s: Wait list for U.S.:
SynctronX - 2 boards.
Once again SyncTronx- i need your quick reply to my PM as I cannot keep holding the spare PCBs. If i do not hear back I will offer those to the next one in line as there are more requests than the available PCB's
thanks
kannan
Glad that someone is actually into making something!!:D
So that is just a package designation for original Toshiba dual JFETS.And no such socket is available anywhere that I am aware of.
So what I did was get these two parts (Its in the mouser list linked at the first page)
90147-1104
90147-1103 and solder them at the 4 pin and 3 pin positions and use a drop of superglue between them. Don't forget to hold them together tight while glue is curing, with a clamp.
The dual jfets will slide in without any difficulty.
DON'T FORGET ,if you don't hold them together they may get pushed to the side by glue while curing.
However ,You do not need the socket or dual switch for board to work with non dual jfets.
I will add this description in first page.
I’ve used these zig zag sockets in the past for stuff like 2SJ109 / 2SK389. You have to cut them, but they work great.
410-93-220-10-001000 Mill-Max Manufacturing Corp. | Connectors, Interconnects | DigiKey
Switch question,
There are two different switches in the BOM,
The first mouser has stock.
The 2nd, mouser is back ordered.
I've seen a pic of one board with the metal vertical slide
switch, but the black plastic vertical slide switch was back ordered.
Does it only need either swich?
My take
