JVC JA S22 squarewave overshoot
I have been recapping a JVC JA S22- (uses STK0040 Darlington pairs), and although everything tests OK with a sine wave- the image attached shows huge overshoot on a 1khz square wave.
what is likely to cause this?
Does the generator waveform have the overshoot also? Make sure the probes are calibrated.
If not, check at each stage's output for the culprit. Most likely to be in the preamp section.
so as this is a "feature" of the circuit (as opposed to a bug)- is there an explanation as to why it does this?- I looked at the tone circuits of Onkyo A7, Pioneer SX and a couple of other contemporary designs, and they have a third transistor in their designs- any suggestions as to where I could read more about this?
as always thanks for your help
Am I correct in thinking these are configured as a darlington pair?
It's a common emitter feeding another common emitter.
The first transistor is a PNP type, so it's upside down (emitter to positive rail).
The feedback from the tone circuit goes back to the input PNP emitter
(through a coupling capacitor), as usual.
If you simulate that mess, subbing an op amp for the two transistors,
you'll see that there's still a HF peak, due to the chosen component values.
If the tone circuit had all symmetric component values for boost and cut,
there'd be no peak, since the two composite tone circuit impedances
(output to wiper, wiper to ground) would be equal, giving a gain of x2,
independent of frequency when both of the controls are centered.
But they aren't symmetric, hence the glitch.
