@still4given,
Hi Terry,
I have 4 of the original P30ZF that alex mm designed and I believe you built. A quick question: "Do I need 1 pcb per channel or 1 pcb will cover 2 channel stereo. Need to know because I am going to sell some pcbs that are gathering dust.
Thanks for the help,
Myles
Hi Terry,
Myles
Hi Mister Mile, as usual one more nice amplifire. How many volts should we put in positve and negative rail, in order to work with 4R.
Pozdrav
I don't understand. The P30 is a preamp. It's not meant to drive a speaker.
yes but it was just for testing. its now working with a40 and its fantastic. thanks for help.😀😀
Great news!
...to be: AX11 XXXL and AX20 XL:
Hello APEX/ Dragan100,
here is a layout for CA4🙂. pl let me know any comments?.
regards
Prasi
Can u share the both PCB layout in PDF?
they are not yet tested...
Mr Mile, thanks for the reply, I made a new PCB. The old PCB took off tracks from the heat with excessive component changes. I will assemble it and make the change according to your orientation, soon I will post the result.Replace 4k7 with 3k3...
regards
Prasi
Option 2 for CA4: compact version for 2U heatsinks.
regards
Prasi
hi mr mile salovic
please share to me final apex a40(pcb+schematic)
i need to made a40.
about ax17 i want tell to you that is very nice...i made and enjoy really...tnx
i need to made a40.
ne555 protection problem
in mono PCB i see that a R680K connected to pin number 4 of ne555.
but in stereo PCB R680k dont connected to pin number4 of ne555.
now which one is correct?
about ne555 protection:Replace 4k7 with 3k3...
about ne555 protection i have problem?!I have connected as in the drawing😕
now it's too late to make changes
It remains like DC and thermal protection
your drawing is correct or must add a overload detector too?
- 100W Ultimate Fidelity Amplifier
