Oh, very similar. If you can send me see code of Atmel?
I don't understand what you think. Hex code or C code?
C code. ThankI don't understand what you think. Hex code or C code?
C code. Thank
how will you fill in the C code into Atmel?
The software to convert to Hex is keil C.how will you fill in the C code into Atmel?
I want to learn how to write your code, if not you can send me the Hex filehow will you fill in the C code into Atmel?
Thank
Thank
OK Thao. That's my suggestion: I'll send you the routines for the LCD and IR receiver. Then, after your 5€ donation, I will teach you to write your own firmware. Do you agree with that?
Ok dd16. So do you have a Paypal account? I'll send over thereOK Thao. That's my suggestion: I'll send you the routines for the LCD and IR receiver. Then, after your 5€ donation, I will teach you to write your own firmware. Do you agree with that?
Yes. Write here your email address. I will send you C code by email.
Mail:Yes. Write here your email address. I will send you C code by email.
Thank
How does it sound Compare with ak4497Sorry for the off topic
I've managed to solder 9018s chip, added the xmos card and it is working flawlessly
Thaocctv,
I haven't listened to the 4497 dac for a longer period of time because of the optical output which I have only on my TV. As I said before, both xmos and amanero card don't work on that dac and that makes it complicated. When I get the time to resolve the issue and make the xmos work, I'll be glad to compare them and answer your question.
It might be obvious to many of you, but unfortunately not to me.
Is the 4497EQ a voltage out or a current out DAC?
It is not directly listed in the datasheet, and I have not been able to find it anywhere else, also not on the AKM website.
The reason it is important to me, is that I have ordered a set of output transformers for my DIYinHK kit, and I were sure it was a voltage out, but now I am in doubt.
I would be very grateful to get the answer from you.
So thanks in advance.
- Digital Line Level
- Dual Mono DAC AK4490/AK4497
