Amplifier subwoofer Gale 3090
Replacing the power amp section is certainly an option but you would need to do your homework and see what other circuitry is on the original board.
The amp in your link is described incorrectly, it is not a digital amp, the TDA7293 is a normal class AB design. There are loads to choose from. Also look at LM3886 chip amps.
This repair Sven Ha680w subwoofer is same to your model
Ремонт сабвуфера SVEN HA680W. Часть I. Усилитель
Circuit diagram
http://zakatayrukava.ru/files/SVEN-HA680W-shema/ha-675-input-board.pdf
http://zakatayrukava.ru/files/SVEN-HA680W-shema/ha-675-amp-board.pdf
I attach the power amp section normal operating voltage for reference.
You should check all the supply voltage, for the power amp section check all resistor and transistors ok or not
Thank you !
I'll start now
