I started work on the bookshelf speaker for a friend. Now this is something special, I can't stop listening to this speaker. Phenomenal coherency.
Anyway, I got G2 ribbons from nice diy fellow here, I got betsy wow from 'd to the g', and placed betsy wow in closed box (ikea bookshelf).
I removed the dust cap, installed brass phase plugs and coated the cone with the 'wet look' from parts express.
Measured the response, I can post it later, it was gently rising, minor breakups, rolls off at ~10kHz. I applied the bsc (0.5mH, 10 ohm) to flatten the response. Measured again, added ribbon, settled on 2uF cap. Nothing more. Flat fr response, flat phase (i tested in and out of phase). I listened with and without sub, sub is optional, depends on personal preference.
Anyway, I build betsy and ribbon before (old thread somewhere), this approach works. This time result is even better.
You got to hear it to believe it.
very interesting
What woofer is that?
Would it be possible to see FR ( on and off axis ) of just the woofer/ box with crossover ?
This looks like a good example of a small voice coil woofer and its ability to disperse well into upper registers ??
It is the Betsy, (With out Whizzer). As found in the https://www.diyaudio.com/forums/wild-burro-audio forum.What woofer is that?
Hi adason, do you believe the wow is coming from the little loss of energy on and off axis between 2 kHz and 5 Khz ?
What's the nice subwof model please ?
Yes, when I get home, I can post fr response just the betsy wow.
MUCH appreciated!
Ah understood... Betsy is the model driver, a FR USA made...
Thanks adason for the link, yes reader of TG website too.
How your curve looks at listening position ? The easurement is impressive for a domestic room 🙂 ... no rooms mode in the low!
Measurements were done in close proximity, to avoid room modes. Besides, its not going to be used in that room.
I do manage room modes with ultracurve, in main system and in the HT system.
Measurements done without sub. Just betsy and ribbon.
MUCH appreciated!
just the betsy wow in the closed box, no bsc
Wow !
yea dispersion is a bit better than typical larger VC cones. Lines start separating around 2K rather than 1 K typical of most larger VC 8", but perhaps more important is the fact that 1K to 10K is well controlled. No big peaks here.
Thanks adason
Not bad at all.
The 1-2kHz bump is something I'd want to take out (either with a passive notch or EQ), but those are excellent results for an 8" 2-way.
Chris
Chris
😀 Me want you to write a paper for the AES : "how to sharpen the 1k-2k with a sharpie pen and a japanese stone" !
muc much better than the R//C serie or the notch 😎
BTW, what is the VC's diameter?
GM
My rough estimate would be 26.5mm.
- betsy wow and ribbon
