John Curl's Blowtorch preamplifier part IV
It was explained to me that Luxmans are designed to satisfy demands of the Japanese audiophile market. They tend to look for certain features in audio products, including high frequency looking components and likewise looking design features such as PCB traces.
Current best practices for EMI are to use a ground plane instead of a star. For low level high gain stuff its quite challenging but possible. Really understanding the current flow through the system is the key. Its also really relevant for the clock distribution. Running fast edge clock or I2S lines is also a real EMI challenge. They can all radiate like crazy. You can bottle it all up inside a sealed metal shell (metal sculpture?) but it will get into any sensitive circuitry inside the box.
Good layout and chassis design are one time costs. There is no valid rationale for savings there. Controlling EMI at the source is also good practice. While it might make no difference in the audio output you cannot be sure and why not do it right?
There may be sharp corners involved but they act as inductors and the Z is carefully controlled and that is accounted for in the software. I doubt such sophisticated microwave software is being used in many consumer products and their pcb layout. Though you CAN use 90 degree corners, clock signal jitter is very critical to audio and best methods should be used even if it is a PITA to get the best performance that is possible with pcb layout.
Most high speed use 45 degree angles or less and never 90 degree. Better is to get there with two 45 degree angles. At least use EAGLE software .. I own it since before they were bought and the price then went way up. But still worth it.
Top 10 Tips for High Speed PCB Design | EAGLE | Blog
THx-RNMarsh
Hard to believe. If I had read nothing from you, then this one post would
be enough for your complete self destruction. A completely brain dead collection
of buzzwords without the slightest coherence.
As if a linear time invariant thing, such as a bend could create jitter.
"at least use Eagle software" ROTFL. Entry level hobbyist software, mostly used
for its free, size limited version (as in free beer). I can't tell a product below that
in the pecking order. And you dare to propose it's top 10 tips as educational material?
Hint: Anything that has SN74 in its type number does not qualify as "fast" nowadays.
< Cargo Cult Science >
Audiophiles that look under the hood, that's a stretch. Even more of a stretch is high frequency looking components whatever that means. This is only one step away from gold sounds bright, lead sounds dull.
I understand your frustration but unfortunately audio is always going to attract the freak (fanatic) element. I don't think the forum's credibility as a whole is at stake, but this thread sure smells funny, many don't post here anymore or very infrequently. JC only seems to pop in to stir the pot when he gets bored or it goes quiet
As has been mentioned many times audio signal processing is trivial by comparison, but the "freaks" and FUDmongers will never have it.
The problem is that audio is among the easiest topics in electronics and
beginners flock there for that reason. Once they have tried their first copy
of a gain clone kit they feel like experts. Having no metrology access, the
subjectively perceived sound is necessarily the standard. Understandable
for a teeny, but for an deaf old f*rt, one should expect some progress.
For the hard of google, here is the full joy of the luxman PCB layout. I'll be honest it looks like the hand drawn boards I remember as a kid.
For Balance the measurements Luxman DA-06 D/A processor Measurements | Stereophile.com . Nice -90dB undithered sine wave. Choice of filters for those who are happy with something that mathematically must be wrong. Other than slightly higher than expected jitter on the spdif input a fine set of measurements, just not really much better than a $400 DAC.
The layout must gave been done without computer. It's a blast from the past
when we were using crepe paper and Bishops prefabricated DIL symbols.
When we had finished the artwork, we would spend the rest of the day in the
darkroom with the repro camera.
OK Everyone here raise your hand who has worked with precision complex measurements at microwave freqs? Like to know the name here. Must be at primary or secondary standards lab level. Microwave pcb software user also accepted.
One (me) and others?
Its to help with the lack of credibility issue here.
THx-RNMarsh
Do the 9 ps risetime scope and the uwave vector network analyser 40 cm
from this keyboard count?
ADS, Empower, Sonnet, AWR? Comparing a hydrogen maser and a cesium
and locking them together? The pulse strecher to measure the photon flight time
from ground to ISS with 5 ps resolution? 10 GBPS fiber optic transceivers?
Eagle user? NOT!
Altium 20 now supports any-angle routing so you can get a bit closer to a hand drawn look if you want. I can’t recommend updating yet if you’re using a previous version though; the UI thread freezes with alarming regularity. I have to kill it multiple times per day.
The layout must gave been done without computer. It's a blast from the past when we were using crepe paper and Bishops prefabricated DIL symbols.
No, Gerhard! FYI it can be done in modern software. I did mine in Accel EDA, the predecessor to P-CAD (now Altium Designer).
Now, let's start bashing Levinson products 😀
