Usually either RMAA or Spectraplus.What software are you using for THD and SNR measurement?
Thanks Reactance!very nice work, will you be releasing an updated schematic ?
I can partially show the circuit diagram. I already showed the modulator, it does not differ from the previous model. I’m not showing the half-bridge driver yet, as this is at least some kind of know-how.
Now I am preparing documentation for the production of a trial batch of circuit boards in China, which will be available, including as a kit for radio amateurs in a few months.
Thanks Reactance!
I will be interested in purchasing I trust your work, update looks really good! please let me know about cost ect I will pm you with details.
Greetings!
So this is a rework of UcD high end modulator, isn't it?
Performance seems similar. This modulator shines at low volume and low frequency. Marketing arguments.
But hey, 0.15% THD at 5Khz high volume? I'm getting half of that with a 1st order modulator!!! haha
Hypex is not the best implementation of UcD. IMHO
Thanks! The first batch is already reserved, sorry.
Within a month I will order an additional 20-30 pieces.
Will arrive in about 2 months. . I will report here
Thanks, I will keep in touch keep up the good work!
IMHO
0.15% on 5kHz
Your skepticism needs to be updated.
You were mistaken by 40dB, and maybe more.
Distortions at 5 kHz do not differ from 1 kHz in the band up to 20 k and 1/2 max power.
UсD 1 order from the patent of the respected Bruno gives 0.008% if correctly implemented, 20-20k up to 1/2P. Just not everyone knows how to cook it
Video from post 15. Minutes 4~5. I was not expecting an emotional interpretation of a scientific statement. I will not make further appreciations.
jealousy makes you nasty.
Pardon, Eva.Video from post 15. Minutes 4~5. I was not expecting an emotional interpretation of a scientific statement. I will not make further appreciations.
In the video, a 500W power supply, and with a peak power above 400W, distortion naturally grows.
Near clipping, the loopgain decreases by 30dB, which just gives the desired 0.15%. (and due to the specifics of the limiter + some additional non-linearity) This is true for the output voltage below the supply voltage by 4V.
The other day I will definitely show a graph of distortions from power at 6 kHz for the version on silicon transistors.
Take a break Evita, let Sous Chill and enjoy his creation.
It would be much better for her if she concentrates on something constructive.
Perfect timing these 15pcs arrived today seems like you using them too.
5PCS/LOT SI8233BB SI8233B SI8233 8233BB SOP16 DRIVER CHIP-in Battery Accessories & Charger Accessories from Consumer Electronics on AliExpress
Not sure if they fake.
I bought on Ali si8234 got defective.
waiting for this
https://aliexpress.ru/item/32842339690.html?spm=a2g0s.9042311.0.0.264d33ed1NdlAn
waiting for this
GaNFET drive
I think you are not easy to drive The TPH3206, the switch speed is too fast, easy to self-OSC, the PCB layout requirements are also high, you can try TI's drive all-in-one device, better to use , of course, Navitas is also a good choice, we try to use these devices on the 300-500 100V amplifier, At present, it seems that the effect is perfect.
Experimental design of the amplification module for GaN FET TPH3206 from Transphorm.
Expected up to 500W / 8 ohm.
- Class D
- Amplifier module on driver SI2833
