searching
I consider this part of the DIY Audio forums as a research center run or at least driving by Nelson and his wonderful electronics proposals.
I noticed that most of it are based on "non obtainable" or old new stock of transistors.
Why that ? Can't we find in the actual productions some interesting components ?
For instance, things like this :
CG2H40xx & CG2H30xx GaN HEMTs - Wolfspeed / Cree | Mouser France
I have no idea if these could even be placed into a musically interesting amp, but here is the idea.
..I noticed that most of it are based on "non obtainable" or old new stock of transistors.
All DIY projects was and are made with obtainable transistors.
Just they less actual after 8~10 years for example SemiSouth 😀
Anyways contact EUVL in Group Buys if You want build with this power jfet's.
For exotica SIT's we get verified sources with sellers in Japan etc.
https://www.ebay.com/sch/watanabeto...Y8MAAOSwnbZYDFkx&rt=nc&_trksid=p2047675.l2562
DiyAudio store for matched small signal jfet's
Linear Systems Matched JFETs – diyAudio Store
and Diyers can buy today from Mouser IXYS transistors
IXFN140N20P IXYS | Mouser France
and J112, J113 Fairchild jfet's at very resonable price.
IRFP240PBF and IRF9240PBF cost ~ 2€ pcs.
IRFP240PBF Vishay / Siliconix | Mouser France
OK Greedy Boyz always search for new fresh or NOS but extraordinary linear audio transistors.
Congratulations if You discover a new semiconductors Champion's :Olympic:
edit: last ACP+ preamp use actual mosfets https://www.mouser.fr/ProductDetail...2pyFaduinjWF4iLQYB%2B0BAXbsAjsfak2QDle%2B5J8= Enjoy!
You can try to build a simple Pass-alike amp with it, but lots of experimenting is promised. Keep the fire extinguisher at hand.
Specs are simple and straightforward though. I think it can work.
