Hey guys im having problems with some panel mounted female rca connectors.
I can't seem to get my rca interconnects to fit on them.
What size should these female rcas be?
Is there an acceptable range? Im building a preamp and dont want to use parts
that are not acceptable.
Anyone have any similar experience?
General specifications from Google
Diameter 0.354 in (0.90 cm) (outer, typical)
MCX Connectors | Amphenol RF
any recommendations fot decent quality and not
ridiculously priced?
Switchcraft
Switchcraft 3502ABAU Longbody RCA Male Black/Gold
Switchcraft SW3501FRX Panel Mount RCA Jack - RoHs
The RCA or Cinch socket outer barrel tapers significantly from base to tip.
Yes, that's part of the problem. On the other hand, a straight barrel socket will be incompatible with many plugs.
Anyone have any experience with REAN NYS373 RCA CONNECTORS?
Rean NYS373 RCA Connector w/ Stress Relief - Red [NYS373-2] : AVShop.ca - Canada's Pro Audio, Video and DJ Store
Or the REAN NYS367-9 RCA FEMALE CHASSIS JACK
Rean NYS367-9 RCA Female Chassis Jack - White [NYS367-9] : AVShop.ca - Canada's Pro Audio, Video and DJ Store
I've used plugs like those Rean's, they're nice but not the easiest to solder (they never show the insides of plugs) & they're a swine to get off in some cases unscrewing the jack on the amp/pre as most DIY jacks are secured by a little nut, one which you don't want to crank up too tighly, also in a preamp jacks are usually close together, not easy to get a spanner in.
That said if they're from the same maker they might be ok, thing is that won't always be the case. I'd buy a pair before ordering a load, it's hassle and more expensive postage wise but that's better than having 50 quids worth of bits sitting in a drawer .
Andy.
Andy.
- Design & Build
- Parts
- Female rca panel mount size problem
