Audison LRX5 600 No Sound
Why didn't you say that there were no 8-pin op-amps near the bias pots?
This amp appears to be too different for me to be of any help. I was expecting the design that had op-amps like the one in the photo below.
Perry,
Sorry I was a little confused and I was looking for something that I was unsure about. Here is a picture around one of the pots.
Also after removing some of the heat sinks I found one of the power FET's to be blown. I measure all the center pins and have the 13.24vdc
Without a wider photo or a description of how they're being used in the circuit, I can't offer any more advice than to replace the blown FETs.
You removed the spring clips that hold the semiconductors tight against the heatsink. The heatsink is the large massive piece of aluminum that soaks up the heat from the semiconductors.
Iam looking to replace the power transistors to try to power the amp up for further testing. They are BUZ110S I belive this is the datasheet:
BUZ110S pdf, BUZ110S description, BUZ110S datasheets, BUZ110S view ::: ALLDATASHEET :::
Iam having trouble finding replacements. Is there any part number that these can be changed over to?
Also there are U1620, and U1620R are these the voltage dividers? Should they be replaced? If so what would a good replacement for them be?
I will have to get the measurement to replace the 2.2k gate resistors.
Thanks in advance
Here is a link to a cross-reference source
MOSFET Cross-reference Search | Equivalent Transistors
It shows you may be able to use the IRFZ4410Z which is available through Mouser.
Those are the rectifiers. Something like the MUR1620, again through Mouser. Replace only if they test bad.
Thanks in advance
People may disagree, but when I started repairing amplifiers I pulled the rectifiers out to give me the ability to repair the power supply without worry.
If you do make sure you mark the direction if you have any doubt about the positive, negative relation.
Take it slow as not to confuse you. I see you have another amp you are working on that has a completely different circuit topology.
Bear in mind that I have no information on this amp except what you provide. Good quality, high resolution images would help reduce guesswork.
The 2.2k are likely pulldown resistors.
The gate resistors will be much lower in value.
I suggested 47 ohm. If the original gate resistors are OK and 47 ohms or below, you can leave them.
Here are some more pictures. I will take some better ones when I pull the board from the case.
