diyAudio F5 Build Guide
Thanks for the reply.
Found something interesting, my transistors are running a little hot so i put a strip of copper over the transistor and bolted it down, found that the transistors are running much cooler with a heatsink above them as well.
Basic physics, heat rises.
About the psu, When i build a psu i just use a transformer>bridge rectifier>smoothing caps and it works fine.
In the pass design there is R10 2.2k, what does R10 do, is this not just wasting power.
Also there is R5 - R8, what do these do.
I have heard of people placing resistors across caps to help them discharge, but not in this manner.
Thanks!
FWIW, heat doesn't rise. Hot air does. Heat spreads out uniformly in all directions.
The 2K2 resistors are bleeders (for discharge when the amp is turned off). R5 through R8 are the 'R' in the middle of a CRC filter, which is much more effective than a C filter. A C filter largely just shifts the phase and frequency; an RC filter actually damps the waveform.
Jeff.
Hi!
The power supply has 0.47 ohm resistors between two of the caps, is there anything to be gained by adding resistors between the rest of the caps in a similar manner to help smooth the supply further, would this yield any sonic benefit.
Thanks!
I have these spare PSU regulators (2 total) and I’m wondering if I could use two of them for an F5 or even An F4 or F6.
Each cap is 22000uf and two are on each board (44000 per rail). I’ll have to pull out the resistors to get the exact resistances but there are two on each board. There are bridge rectifiers attached Rated at 35V and 1.2A (KBPC3510).
Would I just need to wire the grounds together?
And what resistor values would I need to have total for each board?
I just did a test of the completed "Universal Power Supply". My first PSU; no smoke! I used the AS-3220 toroidal transformer. With no load, I'm reading 28.9V between GND and V+ although specs on the transformer from the manufacturer are "300VA 20V" is this normal? Same for GND to V-
Also, it takes several minutes for the caps to drain. I tested R9 and R10 before installation and they are the prescribed 2.2k. Aren't those resistors designed to drain the caps? or is this a normal time period to reduce wasted power while the amp is on? (AS-3220 - 300VA 20V Transformer - AnTek Products Corp)
Trying to get used to how hot the transistors are, as i have only used class-a/b amplification before. Can you tell me does this reduce transistor life. Even with good heatsinking it feels unnatural.
Also, if i reduce the bias how will that affect the end sound coming outof the speakers what changes will i notice? Loss of accuracy, distortion.
The power supply voltage is +/- 27 volts, i made the voltage a little higher than recommened to account for voltage sag but there does not appear to be any, would dropping it down to 20 volts reduce the amount of heat producded by the transistors
Is the board affected by psu voltage.
As you mentioned you are concerned about negative affect of high heat on the components, this may reassure you... Specs on the mosfets say: "Operating Temperature -55°C ~ 150°C"
I suggest you make sure the mosfets are mounted properly to your heatsinks with keratherm or similar, then use a point-to-test IR temp meter to check they are within the suggested operating range. Mine get up to around 70 to 80 C.
Do these boards benefit from burn in time. I thought that was only for capacitors, since this is a capacitor-less design, perhaps not.
What are your impressions, did the sound improve / change after burn in, how long burn in did you give the boards.
