Note the form of the equation.
Suppose you start with the process of summing two frequencies, 22.5 and 17.5 resulting in a particular wave shape. You propose that a carrier then exists at 20? If it does, then what happens when you try to filter out only 20, then only 22.5 and 17.5 left? What happens when you filter out 22.5, both 20 and 17.5 left? Did you really end up with three frequencies or only the appearance of three?
Compare the above results with what happens to produce the same particular wave shape as in the above when the process is modulation. Any difference in the results after filtering?
You have to remember that math is modeling of reality, not reality itself. The math for describing a wave shape does not necessarily tell you the waves that are producing the shape.
Thank you.
First is good, second is good, but the discussion is not about the product of two hf sines, but modulation of high and low.
If you add 17.5 K and 22.5 K, it is mathematically equivalent to multiplying 2 times (amplitude) the sine of 20 K times the cosine of 2.5K.
jn
jn
Ah, now I get what you mean. Alas, the zero-crossing distances undergo the same restriction as the spectrum peak when trying to eye-ball carrier freq from it: no additional EQ!Print your graph out, the one I questioned.
Take a caliper, measure the zero crossing distances, first green, then blue.
My printer on an 8.5 by 11 sheet shows blue zero crossings at 24.54mm, green zero crossings at 22.19mm.
Had you slid them to coincide center of wave, you would see that they are not the same.
Oddly enough, they show the filter out as 18.08 khz carrier.
jn
I do not propose anything. The math states that the sum is exactly equivalent to a sine modulated waveform with the average of the two frequencies as the carrier, modulated by the cosine of 1/2 the difference between the frequencies.Suppose you start with summing two frequencies, 22.5 and 17.5. You propose that a carrier then exists at 20? If it does, then what happens when you try to filter out only 20, then only 22.5 and 17.5 left? What happens when you filter out 22.5, both 20 and 17.5 left? Did you really end up with three frequencies or only the appearance of three?
jn
😕 Makes no sense to me. Anybody ever see a multitone (summation) generate sidebands in low distortion system?... Again, there is no waveform distinction between the sum of two sines and the product of two sines (given specific parameters). Any filter is incapable of distinguishing which method was used to produce the sine modulated output.
The math states that wave shape looks the same, not necessarily that the same waves are producing the shape.
Ah, now I get what you mean. The zero-crossing distances undergo the same restriction as the spectrum peak when trying to eye-ball carrier freq from it: no additional EQ!
It is entirely consistent with the trig identity. Well, yours was 18 khz instead of 17.5 khz, I have no explanation for that discrepancy.
But again, thank you so much for your efforts, I really appreciate it.
My point is, overlapping the two signals, that of filter in and filter out, they are not identical. I blame the loss of sideband information for that.
John
No, the math is a trig identity. Exact, they did not use the "~" sign. (I've no idea what that is called, is it a tilda?)
jn
Fully separated from the ongoing discussion that doesn't have my attention, I have the impression that we did not do precisely the same.OK, here we go.
Summary:
- The FIR from the filter toolbox is basically fine while not high precision, and with Hans's parameters it doesn't do any brickwalling, rather a soft-knee shallow-slope response -- "gaussian pulse shaping" the docs say for the "FIR2" type, and the compromised performance is noted as well.
- the brickwalling is actually done by LTspice during output file saving, probably a crude resampling and that is what corrupts the signal spectrum.
Shown below is the FR and GD of the Fir filter that I used and as mentioned before 'not exactly a brick wall filter', but the best I could get in LTSpice with a constant GD for a "quick and dirty test".
But what a difference from your FR ?
The second image shows the output signal of the filter, still completely analogue without any of the staircase-steps that you showed ?
And brickwalling while saving is not what ever happened.
I just made .wav files from the analogue in- and output and played them back in RMAA, because LTSpice makes a mess of displaying a .wav file.
See the 3 RMAA files below.
So in my LTSpice sim I did not do any (re-)sampling, I just made a 44.1/16 .wav file from an analogue signal that was Fir filtered, a thing that LTSpice can do very well.
A proper brickwall as in Audition will of course get much more accurate results.
The quick and dirty job was seemingly informative enough after all.- spectrum as analyzed by Audition looks the same (except the missing 44.1 brickwalling), a slowly increasing drop of magnitude at high frequencies.
Your upsampled spectrum to 384K is probably screwed-up because of doing something wrong in LTSpice.See comparison of original filter output @384k (red), a precision resampling to 44.1k and back with Audition(yellow), and the 44.1k LTspice output upsampled to 384k with Audition (blue). LTspice corrupts the output quite a bit. It has additional droop below 20k and the spectrum looks deformed overall (notches don't match, etc).
Hans
Doesn't matter.
The waveform itself has only one representation in the frequency domain however it is produced.
For human perception it matters if the ear/brain detects/recognizes frequencies or time domain waveforms. There is some research on that, but others probably know what it says better than I do.
Modulation, summing, digital synthesis are some processes that can be used to produce waveforms. There have been claims in this thread about processes and about waveforms, sometimes mixed up in ways that don't fully jive. Hence, the need for a clear statement about what exactly is under consideration. Audibility of waveforms? How waveforms may be produced in digital audio?
Hans, thank you again.Fully separated from the ongoing discussion that doesn't have my attention, I have the impression that we did not do precisely the same.
Hans
Note that your filter output also has a longer carrier wavelength, and is rather consistent with the spectrum plots.
If you overlap input and output, they are again, not the same.
jn
They are magical on voices. Transform Mickey in Sinatra. I never used them on cymbals apart if I wanted a big heavy sound.And yet the old tubed Neumann mikes are still loved and insisted on?
I had been told that Americans and English people were not jealous of the fortunes of others. An urban legend?The point is that redbook rates are more than adequate for domestic replay and there is nothing more than conjecture over if this statement can be disproved. I don't think also that anyone has said that well heeled pensioners should not pay over the odds for hi-rez downloads from scraggy old master tapes if they want to. It's their trying to force it down our throats that we don't like.
That said, think about it. You pay for the CD burning, the cover and the transports. It's free for downloadable files: less expensive..
I'm retired, not heeled at all, and want high definition files. Because it doesn't cost more, because I can always reduce its size and quality if I want. because more is better than just enough.
No one thinks of shaming you because you are satisfied with the little red book. Not my notion of democracy, whatever I find CDs quite satisfactory ... but not perfect.
it don't males a lot of difference if you enjoy music, more if you are a passionate audiophile. That is not a sin neither ;-)
As we say in France: "Butter plus the money of the butter and the smile of the creamery".
Any resemblance to "The last tango in Paris" would be pure coincidence.
The proof is in the pudding. Both Hans and KSTR have now provided exactly the same evidence.Doesn't matter.
The carrier is shifted in frequency away from the initial one.
jn
Thank you for this. Much more eloquent than my "have a close look at the animation I posted....." 🙂It isn't, and any filter cannot change that. You are still mistaking the peak magnitude point of the filtered response as the point where the carrier freq is situated, which is only true when no additional EQ is present, obviously. With EQ, the peak point in the spectrum does shift but the carrier and the sideband frequencies are not changed. In a single cycle of raised cosine window the components have widespread leakage, in the periodic equivalent we see distinct lines at 20k carrier and 15/25kHz lower sidebands and that picture doesn't change when additional EQ is applied to this.
There never was a carrier per say, since that implies creation of a waveform by the process of modulation. Some of the confusion in this thread seems to arise from overly loose use of technical terms.
The trig identity...
...says that more than one process can create a particular waveform. Are we looking at processes that can affect audibility or waveform audibility however a waveform comes to be?
What's this 180 degree phase changes all about. Flipping back and forth with polarity reversal cant be something to improve the sound quality.
-RNM
-RNM
No idea what you are trying to say here!I had been told that Americans and English people were not jealous of the fortunes of others. An urban legend?
most of the time hi def ARE more expensive. When it's the same price of course I take that download option.That said, think about it. You pay for the CD burning, the cover and the transports. It's free for downloadable files: less expensive..
Some try they fail. But I just picked up another mono Furtwangler recording at the post office which will be tonight's enjoyment.No one thinks of shaming you because you are satisfied with the little red book.
I remain convinced that with some people there is a Pavlovian response to the high-res LED on the DAC. Mine doesn't have one so I am denied the dopamine hit that might help me see what I am missing.
FWIW I run my miniDSP at 24/96. Cos I can...
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
