John Curl's Blowtorch preamplifier part III
You gave an example of a 20kHz fundamental which is what I questioned, not that harmonics can go higher. Dog whistles are up there but can anyone hear one other that the hiss of breath?
As a matter of interest what free software can handle 192k recordings? I would be interested in looking at the leading edge to see what the rise time was.
I used those arbitrary numbers to show that amplitude modulation of an (arguably audible) frequency can create side bands that are absolutely out of audibility.
I do not have numbers on cymbal frequencies or envelope, so kept the discussion simple.
Edit: way back in this discussion, someone (IIRC PMA) said that a gated sine was a violation (it certainly is) and showed that it didn't take that long for the system to recover.
Why should a percussive instrument be treated differently?
As I said many moons ago, the reliance on frequency domain analysis only is tossing out temporal information. A neglected domain unfortunately.
Jn
Darn, exceeded my word count quota again..
OK. I remain confused but it's a losing battle with me as I'm stuck in the paradigm of trying to reproduce real instruments in an acoustic environment as being a key driver.
It shouldn't which is why I would be interested in analysing it.
And yet a cymbal recording just presented on this thread had up to 60 kHz content.
My concern is not that we can hear up to there. Rather, how much of the measured spectra is there because a lower frequency we can hear was modulated. Like leading edge of the envelope.
Filtering to limit so as to not violate nyquist will remove envelope modulation upper side bands. I assume only percussive type instruments need apply.
My trivial example of modulating 20 kHz with a 5 k sine should be simple enough for all to follow. What I have never seen is an actual formal analysis on real instruments and their real modulation envelopes to determine what side bands result from the envelope.
This is not rocket science.
Jn
I may have missed it, but what about the comment earlier that modern recording is done at a high sample rate and then downsampled or decimated to hit CD... So, the original sine is well oversampled, so not a fish.. 🙂 How does that affect the sidebands / beats, in theory, in your view?
If you check posting history you will see a number of occasions where my hearing has been called to question so I am well justified in getting pissed off!
Bill, presumably your hearing is normal or better for your age. Also, you are a smart guy with a good brain.
If there is any difference in hearing between you and someone else maybe it is in how your System 1 (from two system model of cognition) processes sound and presents it to conscious awareness. People do seem to vary in that respect, for example some having perfect pitch and some not. If someone is better at pitch discrimination so what? If better at some other similar type of listening discrimination so what again? Nothing to get pissed over, shouldn't be anyway.
... So, the original sine is well oversampled, so not a fish...
Then downsampling and decimation will fishify it? No?
... People do seem to vary in that respect, for example some having perfect pitch and some not...
... Nothing to get pissed over, shouldn't be anyway.
+1
I am younger than Pavel, yet I admit my hearing discrimination is not as good as his. No problem.
