Huge Lot of Parts For Sale
I have the following parts for sale (TAKE IT ALL PRICE NOW $175USD with Free Shipping to Lower 48 & Canada) :
6 Elna Silmic II Polarized Capacitors (4-47uF 50V/2-1000uF 16V)
5 Nichicon KA 105C Audio (3-4700uF 16V/1-220uF 25V/1-47uF 16V)
24 Nichicon Non-Polarized MUSE (2-220uF 25V/8-220uF 16V/6-47uF 25V/4-47uF 16V/4-4.7uF 50V)
1 Nichicon Fine Gold 220uF 10V
3 Nichicon UPW 105C Low Impedance-Long Life Polarized Caps (3-470uF 16V)
1 Panasonic (Mashusita) 100uF 25V NP Cap.
2 MPSU57 Transistors
15 Small Anti-Static bags
1 35Amp 800V Hi-Power Diode Bridge
10 2Amp 800V small Diode Bridge
2 Positive Regulator (317 Type)
2 Negative Regulator (337 Type)
5 Misc Small Heatsinks
LOT of >100 Fuses - Various Ratings
Lot >100 3/16" & 1/4" Male (Blade) Circuit Board Terminals
4 DIY 3' long Alligator Clip to Aligator Clip cables
10 NEW Alligator Clips New in Bag
2 4" Banana Jumpers
2 Solen Crossover Board Stereo Connector
7 Dual Banana Plugs (Red)
4 Single Heavy Duty Banana Plugs
40 5-Way Binding Posts
8 Other 5-Way Binding Posts (White/Red/Black)
24 Nakamichi Banana Plugs (Mostly NEW/a few Mint)
1 20Ft Balanced XLR(M) to XLR(F) Shielded Microphone Cable
1 50FT Balanced XLR(M) to XLR(F) Shielded Microphone Cable
1 6FT 1/4" to XLR(F) Shielded Microphone Cable
1 3Ft 1/4" to 1/4" Microphone/Pro Shielded Cable
1 20 Ft Single RCA to RCA shielded Video Cable with quality RCA's
1 Pair NEW 2' Redco Mogami 2524/Neutrix Analog Cable Balanced to SE cables $25USD/pair
2 6FT BNC to BNC Shielded Hi-Quality Digital/Video Interconnect
1 BNC to RCA Shielded Adapter Cable
4 Hospital Grade 3' 3X16AWG Power Cord with IEC connector
1 Power Cord 2 Pole 5' IEC Connector (No ground pin)
1 NEW Power Cord Male to Female (Medical Grade IEC C14)
8 Thick Tube Dampners (for 6sn7 Tubes etc.)
6 Chromed Cones with Removal Tip (1-1/2" Diameter X 1-1/4" High with adhesive backing)
1 Small Speaker Terminal Plate with Pre-Drilled Holes
2 Metal Boxes (Heavy Gauge) with 8 pre-drilled holes for Binding Posts 8-1/2"W x 3-3/4"H x 6-1/2"D (Used for Emerald Physics Speaker Crossover Boxes)
13 Large Male Grille Connectors
4 Smaller Grille Cups
16 Misc Stereo Component Feet
12 10" Long Heavy Duty 1/2" Glue Sticks
LOT 0.110/.250 Speaker Terminal Female Connectors (>50) with Red/Black Jacket
30 1/4" Threaded Nuts for (Speaker/Cabinet/Feet)
15 Misc 1/4" Bolts
1 Tube/Syringe Silver Oxide heat Sink Compound
1 Chip Quik SMD I.C. Remover
1 Jar Heat Sink Compound (Half Full)
2 6.225/6.25 Ohm 50 Watt Power Resistors Mounted on Heatsinks with Cables
1 Behringer Phantom 48V/12V Interface with Power Supply
1 Behringer ECM-8000 - Needs adjustment/repair
1 Unknown Microphone with RCA Output
1 Radio Shack Analog Sound Meters - Extended neck/microphone
1 Stereo 1/4" to 1/8" stereo Adapter
2 Rocketfish AC Travel Charger (mini-USB) - for Mini-DSP Power Supply
2 Theta DaViD (Pioneer DV-424) DVD/CD Drive/New Laser assembly installed
1 Pioneer DV-424 ( Theta DaViD) Remote
1 Used working Theta DaViD Laser Assembly
Note a few items in photos have been sold..... the above list is ACCURATE for what you receive.
Take it ALL that is listed above for $175USD with Free Shipping to LOWER 48 and CANADA
PayPal for US & Canada & E-Transfer for Canada
NOTE: For ALL other countries (because of weight of the above LOT of Parts) it may be prohibitive to ship but looking in the range of an additional $50USD and 2-4 weeks delivery.
  • LOT 0.110/.250 Speaker Terminal Female Connectors (>50) with Red/Black Jacket - $5USD for LOT
  • 30 1/4" Threaded Nuts for (Speaker/Cabinet/Feet) $5USD for 30
  • 19 5/8" (11 Threads per Inch) Flanged NUTS ( for Threaded Rod Stereo Stand etc.) $9USD for 19
  • 1 Tube/Syringe Silver Oxide heat Sink Compound -$2USD
  • 1 Chip Quik SMD I.C. Remover - $3USD
  • 6 Chromed Cones with Removal Tip (1-1/2" Diameter X 1-1/4" High with adhesive backing - $15USD for 6
    • 4 DIY 3' long Alligator Clip to Aligator Clip cables - $4USD for 4
    • 10 NEW Alligator Clips New in Bag - $3USD for 10
    • 2 4" Banana Jumpers - $1USD for 2
    • 2 6.225/6.25 Ohm 50 Watt Power Resistors Mounted on Heaqtsinks with Cables - $5USD for 2
  • 1 35Amp 800V Hi-Power Diode Bridge - $3USD for 1
  • 10 2Amp 800V small Diode Bridge - $3USD for 10
  • 5 Misc Small Heatsinks - $2USD for 5
  • Lot 10 Small reels of Hookup Wire (12 to 22AWG) - $15USD for 10 reels
  • 40 5-Way Binding Posts - $10USD for 40
I will take all of these if you include shipping.
Sent you a PM
Lowered Price to $319 for ALL with Free Shipping
I have the following parts and stereo components for sale:
1 Behringer Phantom 48V/12V Interface with Power Supply - $9USD
1 Dayton EMM-6 Calibrated Microphone with Case - $19USD
1 Behringer ECM-8000 - Needs adjustment/repair with Case - $5USD
1 Unknown Microphone with RCA Output - $5USD
1 Radio Shack Analog Sound Meters - Extended neck/microphone - $29USD
1 Spare Behringer Microphone Case - $1USD
1 Stereo 1/4" to 1/8" stereo Adapter - $2USD
1 20Ft Balanced XLR(M) to XLR(F) Shielded Microphone Cable $7USD
1 50FT Balanced XLR(M) to XLR(F) Shielded Microphone Cable $9USD
1 6FT 1/4" to XLR(F) Shielded Microphone Cable $2USD
1 3Ft 1/4" to 1/4" Microphone/Pro Shielded Cable - $2USD
1 20 Ft Single RCA to RCA shielded Video Cable with quality RCA's - $5USD
1 Pair of NEW 10" Schiit Audio (Straight Wire) Analog Cables - $10USD/Pair
2 6FT BNC to BNC Shielded Hi-Quality Digital/Video Interconnect $3USD each
1 BNC to RCA Shielded Adapter Cable - $1USD
5 Hospital Grade 3' 3X16AWG Power Cord with IEC connector - $29USD for 5
1 Power Cord 2 Pole 5' (No ground pin) - $1USD
1 NEW Power Cord Male to Female (Medical Grade IEC C14) - $1USD
4 DIY 3' long Alligator Clip to Aligator Clip cables - $3USD for 4
10 NEW Alligator Clips New in Bag - $2USD for 10
2 4" Banana Jumpers - FREE
2 Monster Cable Male Single RCA to Dual Female RCA adapter $3USD for 2
2 Solen Crossover Board Stereo Connector - $1USD for 2
7 Dual Banana Plugs (Red) - $5USD for 7
4 Single Heavy Duty Banana Plugs - $5USD for 4
40 5-Way Binding Posts - $9USD for 40
30 Nakamichi Banana Plugs (Mint/NEW) - $15USD for 30
2 MPSU57 Transistors - $2USD for 2
10 Small Anti-Static bags - FREE
LOT of MPS8099 & MPS8599 (~40 units) Small Signal Transistors - $8USD for 40
2 Positive Regulator (317 Type) $1USD for 2
2 Negative Regulator (337 Type) $1USD for 2
LOT of >100 Fuses - Various Ratings - $9 for LOT
Lot >100 3/16" & 1/4" Male ( Blade) Circuit Board Terminals $2USD for LOT
1 TCC TC-750 MM Phono Preamp with Power Supply - $39USD
1 Pair of Genexxa Pro 7 (RS Minimus 7 Updated) Speakers - $39 USD/pair
1 Niles SPS Speaker Switching Box 4 speakers capability - $15USD
2 Rocketfish AC Travel Charger - used for MiniDSP Power Supply - $5USD each
2 Theta DaViD (Pioneer DV-424) DVD/CD Drive with new Laser assembly installed - $10USD each or $15USD for 2
1 Pioneer DV-424 ( Theta DaViD) Remote - $9USD
1 Used Theta DaViD Laser Assembly - $1USD
8 Thick Tube Dampners ( 6SN7 Tubes etc.) $5USD for 8
1 Set - Neutrik XLR Male/Female Connector - $3USD for Set
10 Misc EMI/RFI Ferrite Slip-On Filters - $7USD for 10
6 Chromed Cones with Removal Tip (1-1/2" Diameter X 1-1/4" High with adhesive backing) - $15USD for 6
LOT of Shrink Tubing - Various Sizes - $4USD for LOT
1 Small Speaker Terminal Plate with Pre-Drilled Holes - $1USD
2 Metal Boxes (Heavy Gauge) with 8 pre-drilled holes for Binding Posts 8-1/2"W x 3-3/4"H x 6-1/2"D $9USD each
13 Large Male Grille Connectors - $1USD for all 13
4 Smaller Grille Cups - $1USD for 4
11 Circular 1/8" Thick Metal Plates (for Emerald Physics EPX/KC-II) for 8" Coaxial Driver Mounting (Holes @ 9" Diameter; 9-1/4"OD x 7-1/4"ID) $2USD each or $18USD for all 11
16 Misc Stereo Component Feet - $2USD for 16
12 10" Long Heavy Duty 1/2" Glue Sricks - $4USD for 10
30 1/4" Threaded Nuts for (Speaker/Cabinet/Feet) $4USD for 30
15 Misc 1/4" Bolts - $1USD for 15
50 #8 X 1" long Pan Head Wood Screws - $3USD for 50
19 5/8" (11 Threads per Inch) Flanged NUTS (for Threaded Rod Stereo Stand etc.) $9USD for 19
1 Jar Heat Sink Compound (Half Full) - $3USD
2 6.225/6.25 Ohm 50 Watt Power Resistors Mounted on Heatsinks with Cables - $5USD for 2
Take it all for $319USD with Free Shipping to Lower 48 and Canada
25% Discount shipping under $100 USD
50% Discount over $100 USD and under $250 USD
FREE Shipping over $250 USD
