Vacuum cleaners
Cats, the ultimate mics!
What is it with cats and the fear of vacuums? Nature abhors and vacuum and so do cats!
Well don't forget:
"Cats
Cats have excellent hearing and can detect an extremely broad range of frequencies. They can hear higher-pitched sounds than humans or most dogs, detecting frequencies from 55 Hz up to 79 kHz.[20][21]
Cats do not use this ability to hear ultrasound for communication but it is probably important in hunting,[22] since many species of rodents make ultrasonic calls.[23] Cat hearing is also extremely sensitive and is among the best of any mammal,[20] being most acute in the range of 500 Hz to 32 kHz.[24]
This sensitivity is further enhanced by the cat's large movable outer ears (their pinnae), which both amplify sounds and help a cat sense the direction from which a noise is coming.[22]"
Hearing range - Wikipedia
"Sigh, must you with the screamer?!?"
Jeff
PS Can you image the imaging! 😉
Well don't forget:
"Cats
Jeff
You really don't want to know how some folks determined the hearing ability of cats.
Seriously now is a good time to quit reading.
XXXXXXXX
It is very easy to get free test subjects from folks who have un-neutered cats. They put electrodes in the cat's brain. Then they clamp the test subject's head in a vise. Apply the stimulus and look at the EEG. (I told you not read this!) The cat is disposable after the tests.
I was recently told a story about a guy who owned a python that grew very big.
He used to lure a local cat into the house and go out to the bar for a couple of hours.
When he got back all he had to do was check that the python had a bulge in it.
