LDR Pre MkII - LDR volume control and I/O switching
Signal path: USB DAC>LDR Pre MkII (vol=35)> Scarlet 2i2. Digital ground connected to chassis, calibrated.
Cool. I like that a lot. Does it include a remote start for an amp with a trigger? I've got the boards, but haven't started the project yet.
There is a connector which can control relay to turn on power amp. Amp is powered up by left or right encoder button (or holding play on remote for 3 seconds), turned off by left encoder button.
So far, the most accurate distortion measurement I could produce at worst case volume position, 35. Signal path: Scarlet 2i2>LDR Pre MkII>RMI-FC100>Scarlet 2i2. It's a non-calibrated measurement, which means it includes THD from amplifier and Scarlet 2i2, which are probably negligible anyway compared to LDRs.
Can you measure just the fc100 please and post in the appropriate thread?
Cumulative frequency response, LDR Pre + FC100, volume at 35 (worst case scenario), 1W into 8 Ohm resistive. At first, I thought I was getting the same rolloff at 10KHz as some other measurements out there, but it was actually coming from Scarlet 2i2. After soundcard calibration, it's just boring flat. Or maybe I am doing something wrong:)
Hi Neb
I'm putting the BOM together and I've got a Q re the wattage of the resistors for which no parts number is mentioned in your google sheet. Will the following values be OK? Reference is a Mouser part number.
220K metal film 1% 756-MFR5-220KFI 3/4W
500R metal film 1% 50PPM 71-RN55C-F-500 1/10W (Alternative would be 1/2W, 100PPM
2K2 metal film 1% 50PPM 279-H82K2FCA 1/4W
1K metal film 1% 660-MF1/4DCT26A1001F 1/4W
10K metal film 0,1% 660-MF1/4DCVTR1002F 1/4W
ElEsido
Here is the photo of the finished device.
I think you are referring to C30 marked as 470uf 10v electrolytic cap very close to the IC. So if its C30 you said like use anything from 470-1000uf 10v and I have a spare 470uf 63v cap which is fitting in this place. Can I use the same?
But on the extreme right there is another cap very close to the first relay which you have used on your build. I was referring to this cap and the value and if this is required to be used as I do not see the mention in the BOM.
