James Solomon wrote the same things in July 1974. But since his article was in a professional journal for degreed EEs (IEEE Journal of Solid-State Circuits), for the most part only degreed EEs are aware of its existence. Bob Cordell's book quotes from it extensively, perhaps because Cordell himself is an EE with a long and storied career at Bell Labs. You know, the place where they invented the transistor.
link to Solomon
Don't be scared: the Blameless power amplifier is just a great big opamp. So is the HPA-1. So is the Hitachi. Same design principles throughout.
link to Solomon
And finally, I leave you with this little gem (same source):
Jeff.
Yeah, bloody dumb bastards.
Everyone, with at least half a brain cell, knows, 2 + 2 = VEGEMITE
Pico,
Please could share some basics(general) of you regulator, so we may prep.
I would like to start a pre-amp thread after that.
Jam
I might post it in the thread I started before I went MIA and post it here.
Just give me at least another day just to be sure it can't be significantly improved further, I am currently running out of ideas to try.
Well I am sure it still will be tweakable for further incremental improvements, but apathy sets in at some point.
I want to thank Jeff, Pico and Jam and others for an informative exchange of circuit topologies. I have enjoyed following along.
BDP
BDP
A mathematician buddy of mine has a button that says:
2 + 2 = 5
and then in very small print under that:
for very large values of 2.
Hi Jam,
No, they're just flipped around to make wiring easier. The top (from left to right) is driver, cascode while the bottom is cascode, driver.
Of course it would have helped if I had given you guys the schematic. 😱
There was an error in the bias spreader, though. It still had the decoupling capacitor from the single-ended-VAS Beefcake.
Fixed version:
Fixed version:
Hi Jeff
I’m just thinking about adding the option of loading VAS stage to make it sound more like a first watt amp.
It’s just an option to play with to get the sound you want.
Also you could put a 2 ohm trim pot connected to the sources of the jets and the feedback loop to adjust the sound to your liking.
1 Ohm source resistance on each jet is virtually zero degeneration and you get some adjustment.
If you didn’t want to add it you just put in links.
It will make the amp pcb way more versatile and give people more options for tweaking.
Yeah.
I’ve driven F6 directly from DAC
Basically all of the amps with 15dB or less voltage gain and a decent amount input impedance which all of them qualify.
Yeah.
Sorry, meant which DAC?
If it’s not loud enough you could increase gain by 3dB or more or vice versa.
My son thinks 15dB is loud on speakers of average sensitivity.
Oppo BDP95
Elac Streamer with built in DAC
One other which my Alzheimer’s fails to play ball with
I see. The Oppo is a rather poor sounding example of an ESS ES90x8PRO evaluation board, IMHO. No wonder to play with the sound of amps in that case.
DACs can be far better sounding. Rather than amps, DACs are more of the focus of my audio hobby. At least for now 🙂
Jam knows since we live in the same town and visit regularly.
Anyways, if you or anyone else is interested in really good DAC sound, maybe we could find an appropriate place to talk about it.
- JamJar: an HPA-1-inspired power amp
