Open Source Monkey Box
Very well done! The walnut is very appealing for this speaker.
Besides the look, technically this speaker is very recommended to built.
I don't understand why the aluminum isn't applied on the baffle ( beside it).
It's the place where the major forces apply to the surface ( the basket's vibrations) and where you would want neutrality. Minimum 1 cm sheet would be needed and, TBH, I haven't done it yet 😱
I could have done the aluminium sandwich thing for the front baffle, but I didn't for practical reasons. The shop didn't want to do circular holes for the drivers.
Most of the front baffle surface is consumed by the drivers anyway, very little would be left for the aluminium sandwich. The woofer is suspended by the two side walls and the bottom. The little piece of front baffle next to the tweeter and midrange is supported by the internal bracing. Overall, the small part of the front baffle that is not covered by the drivers is very "dead" in the knock test.
Mmmhh, it doesn't stand: a knock test isn't the same as a woofer working.
Moreover, you attached to the same structure either the midrange and the tweeter. Those are subject to a continous knock test during functioning.
Probably it's better to leave only the wood for suppressing the vibrations 😱😉
mbrennwa, do you already know what the cost for the complete speaker will be?
I have asked myself exactly this question this morning 🙂 I intend to make a list of the drivers and the xover parts with the involved costs sometime soon. The costs of the cabinet depend a lot on the materials you're going to use, and if you make them yourself or have them made professionally by someone else.
will the crossover components be inside the cabinet for the final version?
I like to keep the x-overs outside the cabinet. In this particular design the x-overs are rather large, and they would take up quite a bit of space within the box. Also, keeping the x-over parts away from the mechanical vibrations in the box is usually a good idea.
The speaker looks fantastic, wooddwork is top quality, as well as design!
Thanks! I have to admit that I had some help from a carpenter (I don't have the machines to cut large sheets).
Can we see measurements of the final version?
The measurements are scattered all over this thread, you just have to find them 🙂 I added some pointers to the first post of this thread (scroll down), but I am sure there is more.
I am still in the process of compiling and sorting out all the data. Some of this is already in the documentation PDF, but there is more to come: osmcdoc/osmc_paper.pdf at master * mbrennwa/osmcdoc * GitHub
I just googled the drivers and saw that the drivers alone would cost more than 1.000 USD for each speaker. wow, that's more than i expected. but I have to admit that those midrange domes do look damn good!
thanks for answering all the other questions!
I finished the second box!
I am sill waiting for the last bits and pieces to complete the final build of the xovers. In the meantime, I have worked a bit on the documentation. I guess this still needs some polishing here and there, but most things are there. Would anyone like to have this published in a proper journal? audioXpress is gone, and so is Linear Audio. Thoughts?
GitHub - mbrennwa/osmcdoc: Documentation for the Open Source Monkey Coffin
Looking at power response i was wondering - aren't you just a little bit worried about that hump from 700Hz-1300Hz ? Have you tried to linearize it and have a listen for subjective differences ? The coloration might not be insulting to he ear but given it is a power response graph, it is there.
It might be just my ocd speaking but it itches me when i look at it - more so because rest of it is done with more attention than what i've used to see (taking the restraints of the design target into consideration).
I know what you mean, I thought the same. I did try to reduce the SPL a bit in the 1 kHz range. My ears preferred it the way it is. I guess it all boils down to how we perceive the sound, and how this relates to the measurements and diagrams. Sometimes speakers sound better if we don't completely remove the acoustic imperfections from the measurement results.
