Need some advice and modify and understanding a plate amp mod question.
Hello, and thank you. I have a ht in a box subwoofer by what orginally appeared to be a white van productuct but upon opening and further inspection I've discovered quality parts. Well I'm new to diy but have a strong technical background and would like to build a powered home sub from perhaps spare components or parts I can acquire cheap.
My question is this. I have a 5.1 subwoofer, with a toroidial transformer and solid construction missing original subwoofer. Can I modify the 5 channels of the amp and add their output power to make one powerful sub amp as I have no use for so many channels. I also aquired a passive sub from bic America with a nice xover and what appears to be dual voice.coil. how would I figure out the value of the xover, and should I implement it? Any ideas? Thank you
Looks like junk parts to me.
No.
passive sub from bic America with a xover, how would I figure out the value of the xover
you mean the crossover frequency ?
rough guide, plug the dcr of the driver and the component values into an online crossover calculator.
it wont be technically correct but should give you a ballpark figure.
So you cannot combine the 5 satellite channels into one more powerful channel for a subwoofer?
English is obviously not your native language.
Maybe this link will help clarify my previous answer.
Really ? In what field ?
