They already list it as new 🙂Audiophonics will have both TransportPi and ReceiverPi in stock.
USB for Receiver Pi
Good morning Ian,
is there a USB2i2s input board you would recommend for the Receiver Pi? I do have a left over JLsounds board which is an isolated board and has got its own pair of clocks. I think I could use it but I would like to use a more simple one, which might be easier to connect and supply with power.
Cheers, Ernst
Good morning Ian,
Cheers, Ernst
Low jitter ROON transport
Low jitter ROON (or other player) transport
TransportPi + FifoPi + RaspberryPi 4
TransportPiFifoPi2 by Ian, on Flickr
S/PDIF FIFO
Independent S/PDIF FIFO:
TransportPi + FifoPi + ReceiverPi
Raspberry Pi free solution
SPDIF_FIFO by Ian, on Flickr
@druidaudio
TransportPi works with all boards that have MCLK output. So, should be no problem.
I'm highly recommended to use u.fl coaxial cable for better signal quality and lower jitter. If you don't have this connector, you can make a DIP to u.fl adapter cable by soldering DIP terminals to the other side of the supplied u.fl cable.
Ian
Ian
Does it need a RPi4?
Absolutely no🙂.
TransportPi works with any any RPi. Pi2, Pi3 and Pi4 are all OK.
It can even work without a RPi.
Ian
@druidaudio
Ian
Hi Ian,
Thanks for this, as I have 2 Kali boards, it makes TransportPi a much more attractive option.
Hello,
I'm new on this forum and I'm very interested in this soulution - TransportPi + FifoPi + RaspberryPi 4.
I have read that it is working with ropieee or volumio.
I would like to ask what HAT option should be chosen with TransportPi+FifoPi?
for example in ropiee for allo didigone i use digione Audio Output (HAT) but what for TransportPi?
Thank you
Hello,
Thank you
You only need to select the general I2S device in the software. That's all you need to do.
Ian
looks good !!
I never cease to be amazed at what a prolific designer you are. You turn out a lot of great designs ... doing it part time. Well done.
Thanks Wlowes, unfortunately that's my hobby😀
Good weekend.
Ian
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
