Acoustic suspension(sealed box) using 2 woofers
Hello everyone,
Let's assume that we want to use 2 woofers per speaker in acoustic suspension design (closed box).
Each of them needs 20lts for an optimal 0.7 Q, and both woofers have exactly the same characteristics (same woofers).
->Would you prefer to use 2 separate closed cabinets of 20 lts each or mount both of them in one closed box with total internal volume of 40lts?
Thanks for your time.
ps. Our only consideration is the best sound quality, not total cabinet cost/size etc.
2 Boxes are easier to transport and give more placement options; more options to get a smoother bass response in the room. (nice for subwoofers)
If drivers share a box/volume; don't wire them in series, only parallel as otherwise the little differences between the drivers are amplified/magnified. (2 drivers are never 100% identical)
There's a few wrong assumptions here. Acoustic Suspension is NOT the same thing as closed box. :D
THIS is Acoustic Suspension:
490322d1435199547-classic-monitor-designs-acoustic-research-ar4-jpg
An AR4 loudspeaker. Designed by Edgar Villchur, Roy Allison and Henry Kloss about 50 years ago:
A Glorious Time: AR's Edgar Villchur and Roy Allison Allison Part 1 | Stereophile.com
Edgar Villchur managed to build big bass into small boxes and ended up with about 50% of market share for a decade.
A good idea can always be improved. The Gale 401 was based on two Acoustic suspension drivers, parallel wired in a common enclosure, which makes for great bass and drums:
483804d1431999040-familiar-gale-401s-gale-401c-restored-martint-jpg
687003d1529097418-passive-passe-steen-duelund-2-828427-2root2-png
I really don't know if parallel wiring or series wiring is better in a common enclosure. Time will tell. For sure, parallel wiring can lead to difficult low impedance for amplifiers. The Gale was notorious for destroying amplifiers! :eek:
What is different about acoustic suspension from closed box, is the bass units have huge magnets and low Qts near 0.38, and heavy cones with low Fs and rely on the air-spring for the restoring force. Closed box uses small magnet drivers with a Qts near 0.5. In fact, Qts 0.5 drivers are hard to find these days. Most modern speakers are reflex.
What is the config - 2 or 3-way?
Internal standing waves might be a problem with a 2-way and large common enclosure (playing up to 2-3kHz).
You can study this with some room mode simulators that work also with small dimensions.
To play safe, 2-way should have separate boxes, which might have a minimal pressure release aperiodic vent in-between, if you want.
If bass-tuning is intended with bass-reflex or transmission line, all this gets much trickier! Too tricky for me actually...
Hello, large multiway, the woofers will play frequencies from about 20Hz to 120Hz.
Thanks for sharing your thoughts about 2 way speakers and possible cabinet issues around 1-3kHz.
This has been nagging me. Series or parallel wiring in a common enclosure.
Thought I'd figured out that series wiring was best, especially with high output impedance amps:
522536d1451743145-isobaric-loading-mtm-bass-loading-current-png
Now, I'm not too sure!
This is an Allison 1 or 2:
628055d1501378412-classic-monitor-designs-allison-speasker-jpg
Seems you can wire it either way:
628056d1501378412-classic-monitor-designs-allison-crossover-jpg
stereonomono - Hi Fi Compendium: Allison model ONE
Maybe we worry too much! In the vaguely related isobaric speaker, Jeff Bagby ( who knows a lot!) thinks series or parallel is just a design choice:
Isobaric subwoofer design, many questions! -
Techtalk Speaker Building, Audio, Video Discussion Forum
But it's a worry to someone as OCD as me. This is actually the same problem as a car differential in engineering terms: Differential (mechanical device) - Wikipedia
FWIW, in PA systems, separate enclosures are preferred. If one woofer blows, the other one stays acoustically loaded, so will survive.
