Hello to all.
I can repair most of the SD amps, including the large 35K, and i can flash the micro to the latest software version.
In some cases i might be able to buy parts for technicians, but please, do not ask me about part numbers.
Due to legal agreements i am unable to disclose any such info.
Hello ultra
I have problem need to fix my amplifier. SoundDigital 35000.1D POWER
last week i bought an amplifier unfortunately faulty the yellow light on, and no output. .What do you think the problem is How much does the repair cost where should I send the amplifier How long does it take?
Peter
Peter
how can we send the amp to you for repair and where are you locatedHello to all.
I need my sound digital exo x 1200.4 repaired the first one channel went out the the sound started going out intermittently. lastly I started noticing that when I hit a bump it started going in and out I know it's the amp because while it wasn't playing I tapped the amp and it came onHello to all.
I have a 1600.1D. stays in distort mode as soon as powered. 254-374-4029. ThanksHello to all.
Hello. I have a sound digital 800x4S evo that has a channel out. Can you repair it? If so could you text me at 979-709-2073. Thank you
Can you fix soundigital 8800.1d ?Hello to all.
I've got a 1200.4 evox2 that has some issues. I believe it is because I plugged it straight into the HDHU14+ headunit and something about the equipment having different grounds. I now have a hum coming from the RCAs. That will get worse if I actually touch the RCA input. I'm located in NC, USA.
Thank You
Thank You
Where can I get info on your repairs. I have a stack of them I need repaired.Hello to all.
I need a 2400.4 repaired. Accidentally hit a button while tuning that gave max input to all channels. You can still hear some sound, but sounds like a whisper….Hello to all.
I have a SD 800.4 EVO amp that started going from loud to very quiet and then quit amplifying at all. Can you fix it?
Thanks, Terry
Thanks, Terry
- General Interest
- Car Audio
- Soundigital Repairs
