Is there any difference in matching JFETS vs DMOS Fets? Need to mach some ZVP4424A and ZVN4424A. Found this device and can it be used to match these?
JFET Matcher Kit - Stompville Shop
The title of the ZVP4424A datasheet says "ENHANCEMENT MODE". That means its Idss is zero. However JFETs are depletion mode devices; their Idss is not zero. So a JFET tester will not give correct readings on enhancement mode MOSFETs.
_
Ok, thanks.
