Maximum output power for Ri = RL is only true if you can freely chose RL. With audio where RL is fixed at 4 or 8 ohms, max power occurs with minimum Ri. The smaller Ri is with respect to RL, the more power is transferred to the speaker.
Jan
The interesting question, with class D amplifier: Ri is Z (w), so that we no longer have a simple resistor divider as class A and class AB amplifiers.
Well, he wrote about the linear phase.
Review and Measurements of Benchmark AHB2 Amp | Page 17 | Audio Science Review (ASR) Forum
A non-linear phase response may be more audible than a non-linear frequency response. Errors in the phase response may create the impression that the frequency response is different.
The frequency response of the AHB2 extends down to 0.1 Hz and up to 500 kHz so that the phase response is linear within the 20 Hz to 20 kHz audible band...
More about phase response here: Review and Measurements of Benchmark AHB2 Amp | Page 17 | Audio Science Review (ASR) Forum
But there are lots of power amps that start to roll of at 30, 40, 50kHz and that have much larger phase shift than the Benchmark, which is really the exception here. What is the phase shift of an nCore at 20kHz, anyone knows this?
Jan
Jan
Phase shift in class D amplifiers. How it affects the sound?
Hypex NC400 phase shift, about 16º at 20 kHz
BOSC - HiFi Monoblock Class-D GaN Amp
Phase shift
[Big IMG, link] http://maty.galeon.com/WP-imagenes/hard/BOSC-HiFi-Monoblock-Class-D-Gain-Phase-8ohm.png
Phase shift
No phase shift till 30kHz. At low frequencies the phase shift is not there and an artifact of the analyzer's AC coupling.
Indeed, the folds in the human outer ear (pinna) introduces minute phase shifts of order 1-2usec. Our brain uses these phase shifts, which are asymmetric depending on orientation of sound relative to pinna (asymemtric), to determine directionality. This directionality does not depend on stereo reception. Try using one ear and see if you can hear direction from above or below or front or back. These shifts correspond to frequencies up to 300kHz. Hence, amps should be designed to be flat phase up to 300kHz or best spatial imaging.
Here is paper documenting phase shift perception in human hearing:
http://www.dtic.mil/dtic/tr/fulltext/u2/600151.pdf
So we hear frequencies up to 20kHz, but use phase shift information up to 300kHz. Using info and "hearing" sound are different. The directionality in itself, is not music/sound. Sort of like encoded metadata in a jpg.
Nord Three SE 1ET400A Dual Mono Stereo Amp Review | Audio Science Review (ASR) Forum
Corrected results of Hypex NC400 is much worse!!!
Review and Measurements of Hypex NC400 DIY Amp | Page 10 | Audio Science Review (ASR) Forum
I have asked to amirm to measure the phase shift of the PURIFI 1ET400A:
Useful only if you have speakers that can reproduce 300khz and source recordings that contain this information.
Ever had a hearing test? According to my audiologist most people don't even get close to 20khz ... my personal hearing runs from 40hz to about 13khz ... apparently that's better than most people my age. The average in his practice is something like 50 to 14k.
This subject is very interesting.
Especially because we´ve devolloped our own class D amp which has 0 dgr. phase shift troughout the audioband.
"We" are four guys who decided to do some cool electronics, end will be referred to as we.
We have used ICEPower 1200AS2 as one of our references in the devellopment process just as well as nCore 500.
Our experience with the pretty large phase shift compared to 0 dgr´s is, that you obtain pretty much better 3D with no phase shift.
Also the sound seems more homogeneous in some sense.
It is a bit more straight forward to listen to.
That said the ICE 1200AS2 is an awesome amp, with both a lot of power and subtle detail. It is a full bridge design, which will not be able to compede on data with half bridge designs.
And an important note is, that i.e. Hypex nCore 500 is only 14 dB gain against 26 dB og the Hypex.
Our own module is 26 dB gain, 25µV noise, and a calculated Zout of only 9 µOhms. we need to do Kelvin measurements on that later on.
You can read more in our survey thread : Survey on class D project
Hopefully this week amirm can measure the phase after changing a small fuse that burned out of the Nord with PURIFI 1ET400A modules. And a picture of inside.
Can you share your phase measurements of Icepower 1200, Hypex NC500 and yours?
BOSC 0º at 30 kHz. How many kHz have you reached with 0º ?
We did not measure 1200AS2, because ICEPower products always measures as they say they do.
I´ll se if I cand find the phase measurements, or maybe we will have to do them again, så be patient please
Hi maty why are you so hooked on that BOSC graph, i mean you look selective only on the phase curve and get impressed by that, but look at its amplitude domain and notice its distorted in not being a flat linear curve but has a overshoot up higher before it rolls off as a rock probably with higher order slope than is normal for analog amps and thats why phase turn in deg at 20kHz point get so low.
Are you aware in physics for nomal natural sounds then phase pattern follow amplitude domain called a minimum phase device or feature, we can probably break that pattern with modern compensation or fir filters using DSP but why would that be good other than get a stand out sound that don't belong to this world.
Up the bandwidth will enhance phase, but 0º at 20kHz is probably impossible when at same amplitude is flat linear, for example a 1st order roll off at 1mHz perform about -1,2º at 20kHz and the 300kHz bandwidth xrk971 ask for is at about -3,8º at 20kHz.
In past thought you were looking for if some class D amps breaks being a minimum phase device and that i could see was interesting point, but as time goes it looks you think get phase at 0º @20kHz by any means is key to perfect performance and that sounds honestly as a noncense argument, also because real world at 20kHz point we tons of decades down because a microphone cascaded a tweeter cascaded our ears will roll off at 20kHz ways down.
BTW that BOSC overshoot you can virtual set for any other amp using your player Jriver to copy that hot boost up there.
I am not hooked on BOSC and its measurements. Only that phase deviation at 30 kHz is almost 0º, so far the best result I have seen.
I will be satisfied that it is a minimum at 20 kHz, that is, that class D meet the same criteria that class A and AB meet without many problems.
About JRiver MC, DSP, rePhase, minimum phase...
* Minimum Phase vs Linear Phase | Page 7 | Audio Science Review (ASR) Forum
* Minimum Phase vs Linear Phase | Page 16 | Audio Science Review (ASR) Forum
BTW, from some days I fixed mono at 4.2 ms
I clearly appreciate the differences, at least with the high quality recordings (and high dynamic range too) I usually hear.Delay:
* Films, series: 1 ms or 2 ms
* Music: 3 ms
* Mono: 4 ms
* Orchestral: 5 ms
A very cheap class D from China.
Archimago's Musings: MEASUREMENT: Yeeco TI TPA3116 Class D Amplifier (aka Nobsound NS-01G, Douk Audio F900S, Mogu F900S)
![Yeeco_FR_and_Phase.png](https://1.bp.blogspot.com/-sm2DNFaf2No/XcpRTHZEDII/AAAAAAAAVVk/mSI66pTeglgEFnUdJoof94GLThq9dm0-gCLcBGAsYHQ/s1600/Yeeco_FR_and_Phase.png)
Hopefully soon we will have more phase measurements from more expensive class D and much better implemented.Clearly the flat phase response of the DAC output as shown previously has been affected passing through this inexpensive Class D device. I've already measured Class AB devices where phase remains flat compared to this. It will be interesting to compare this with better Class D amps in the days ahead...
Another reason I wanted to measure this device is because this is a Class D amplifier. We are currently well into the ascent of Class D designs and I would not be surprised if by the end of the 2020's, almost all new devices are Class D by then for many good reasons! What we see in this device is a reminder of various limitations we should be aware of - potential low damping factor, phase variation, and ultrasonic noise.
- Class D
- Phase shift in class D amplifiers. How it affects the sound?
