Ported sub with dual 12" drivers - build pics
Hey guys,
I started building a ported sub with two 12" drivers for my HT.
It is just half way through, see the attached pics. Will post some more pics as i progress.
Naveen
well... as per simulation, this sub should give the following output:
This has F3 around 31Hz, F6 around 27Hz and F10 around 22Hz.
With 400w power it is expected to deliver 114db@31Hz, 111db@27Hz and 106db@22 hz.
Simulation graph is nearly flat and has a smooth rolloff. Group delay and vent air velocity etc are decent.
Actual performance has to be measured.
Nice! Regarding the actual permance, biggest contributor there will be the room you intend to play it in.
