Low-distortion Audio-range Oscillator
One dual opamp. Do you suspect crosstalk?
p.s. I will do the measurement with the 10nF cap this evening.
Since the line level follower problem is interesting, I made the same setup and got the results.
Also first about the post notch amplifier. Here are measurements without the input follower. 2V RMS at the passive notch input, and the same 40dB post notch amplification:
NE5532:
https://content23-foto.inbox.lv/albums/v/viccc/FollBuf/NE5532noB.jpg
LM4562:
https://content23-foto.inbox.lv/albums/v/viccc/FollBuf/LM4562noB.jpg
OPA2134:
https://content23-foto.inbox.lv/albums/v/viccc/FollBuf/OPA2134noB.jpg
So, the difference is negligible and no distortions are visible.
Now measurements with the follower before the notch.
NE5532:
https://content23-foto.inbox.lv/albums/v/viccc/FollBuf/NE5532.jpg
LM4562:
https://content23-foto.inbox.lv/albums/v/viccc/FollBuf/LM4562.jpg
OPA2134:
https://content23-foto.inbox.lv/albums/v/viccc/FollBuf/OPA2134.jpg
So, the LM4562 is not the best choice for high level signal non inverted follower, but the NE5532 is good in this place, but also is not good enough for ULD measurements.
Also I made the same measurements with the separate post notch buffer and got the similar results. Probably the crosstalk is not the problem.
I use the AD797 often, because it has very low and very simple distortion (only 2nd and 3rd as far as I can tell).
The circuits I use never have noise gains high enough for the distortion cap to make any difference, so you might not find the need to use one. I think you need to be running well above 20dB of noise gain for it to matter. Of course, you can try it out, but I've never seen any difference with noise gains less than 10dB.
FWIW, my experience with non-inverting stages (followers) has not been good - I cannot find one that can provide distortion below about -140dBc or thereabouts, whereas the same chip as an inverter can often do 10-15dB better. Driving 2kΩ or even 4kΩ is pretty easy for any competent amplifier, and the extra noise of an inverter is often not crippling.
NE5532:
LM4562:
OPA2134:
NE5532:
LM4562:
OPA2134:
Very surprising! Do you have the OPA1656 at hand?
Douglas Self has already examined the AD797 in his book and the results were unconvincing. The LM4562 performs much better.
I'll leave it for now.
