Vintage Philips speaker identification
this might help
Certain octagonal Philips 7" full range drivers were specified for a 7 litre sealed enclosure (e.g. AD 7062/M) while others were specified for a 25 litre sealed enclosure (e.g. AD 7063/M).
You can research your loudspeaker by wading through the Philips databooks on this site:
Philips Loudspeaker Databooks
Databooks for 1969, 1978, 1981 and 1990 are supplied.
Have fun!
what should i look for
All you can look for are clues, which is what I did.
According to the data sheets, two versions of the 7" full range drivers were made.
One version had the parameters to suit a 7 litre sealed cabinet while the other version suited a 25 litre sealed cabinet.
You can do an experimental comparison simply by using cardboard boxes.
Such a temporary lash-up should be sufficient to reveal which volume of sealed cabinet is optimum for your driver - be it 7L, 25L or whatever!
found nothing similar to it
Maybe not identical, but certainly similar!
Looking again at the data sheets, the 7 litre version had a rubber surround so we can count that version out.
The 25 litre version had a fabric surround so has the closest similarity to your corrugated paper surround speaker.
That's as much as I can help - experiment with a 25 litre cardboard box and see how it goes.
purchase date vs production date, when you bought them matters little compared to when they where made.
what this driver out of ?
even looking for 2415 264 48001 like a Philips catalogue number doesn't yield an identity which makes me think that's it OEM for a different brand, possibly an organ or perhaps commercial paging product.
